I too am thinking of a sub-frame sitting in the pan channel similar to yours, but with a x brace across the centre? The centre of the X will need to be open with a bridge plate to allow passage of the Suby cooling piping
Once the rear firewall is moved, and an x-brace installed at that firewall, I am thinking to tie it, and the pan sub-frame to the chassis rear as you suggest. The frame head remains VW, but the bottom plate is now 5mm with formed channels, and bolted into the Imhor IFS both at the lower a-arm and 2 piece front plate
The Authorities here frown on a roll cage in a street car, and I have to be very careful not to "modify" the frame/pan
[/quote]
The cage thing is interesting to say the least but I think they must take it as a warning that something is going to happen.
What can you get away with?
This is a body lift I built to add strength to the pan as I have a FG body to sit on it which has no real strength and no roof for working with all kinds of loading. Can you get away with something like this?
The stock seat rails does give some strength to the pan but even combined with the rear seat foot area and the formed stiffening areas in the front when you get too heavy with HP you are starting to push things a bit.
The Imhor IFS does look interesting but again, what are the limitations as to what you can do and get away with? Be sure that the Imhor/the frame head have strong connection to the pan and maybe the firewall too to protect the frame head from torqueing and the possible dam(n)age from that.
Things where I live are getting pretty tight as you could be required to go through an inspection and they can/could be pretty rough on someone. They're not engineers but....
