Hi all,
I'm slowly working on installing a 2.2 SOHC from a '96 impreza into my '70 Baja. I'm deciding where and how to mount the ECU. I understand that it has to be facing the same direction as it was originally but I can't determine if it can be mounted on its edge. I was thinking about a making a panel to go in the cavity next to the passenger seat. Any reason why this wouldn't work?
Thanks,
Ron
Stock ECU mounting
Re: Stock ECU mounting
Why does the orientation of the ECU matter?Wags74 wrote: ↑Thu Jan 05, 2023 6:57 am Hi all,
Thanks,
Ron
Steve
My Baja Build
My Baja Build
If it has some form of yaw sensor inside? That’s about the only reason I can think of but that’s more likely to be linked to the abs / stability module.
1996 wouldn't have any of that. Mount the ECU where it is convenient.
Steve
My Baja Build
My Baja Build
Thanks for the replies. I seem to remember reading it somewhere, I thought in the long conversion thread on this site. I could very easily be wrong about it though.
Thanks again.
Thanks again.
