After lots of research I already ordered a Microsquirt, and LM2 wideband w/ gauge from DIYautotune.
I already have a complete mexican EFI setup. I also have a sweet Vintage Speed muffler, but it arrived without an O2 port. I thought they all had that. So I'll have to find someone that can weld stainless for the O2 bung.
I plan on going with the following,
Trigger wheel and pulley setup from Mario
IAT, CLT, and MAP sensor for mexican manifold from Mario
IGN-4 from Mario
Walbro fuel pump from Mario
FPR from Mario
I've been doing a ton of reading of the MSextra manuals, website, youtube videos, etc. I do have a few questions I haven't been able to find the answer to.
Mario sells a T-fitting so you don't have to run a return line into your tank. Does this work well in practice? I know with the stock mexican fuel pump, the return is run to the fuel pump, not the tank as well. But from what I read, the stock fuel pump pretty much maxes out at around 45 psi, so I probably don't want to use that, right?
Are the stock mexican fuel injectors low or high impedance? If those won't work well for my 1776 I plan on buying a set from Mario, he has the following:
(4) 19# upto 100 crank HP (Stock)
(4) 24# upto 150 crank HP
(4) 32# upto 200 crank HP
(4) 44# upto 300 crank HP
His 19# are out of stock (or unavailable) so would the 24# be too much for a 1776?
The stock mexican idle valve is a VDO, but it looks just like the 2-wire Bosch. Do you think it will work just the same with PWM control?
Thanks for any help and advice
