Bored and stroked EJ207 1303
- Steve C
Steve Carters Orange Beetle SC 201
Body:
1973 L model 1600 Beetle or 1303 which is the official VW model designation. The spare wheel well has been removed to allow the Porsche 944 radiator to fit. The behind the seat luggage area has been replaced with a sealed box that is open to the engine bay, this box contains water to air intercooler, an ice box and the fluid pump for the intercooler are mounted inside the car. Mudguards are fibreglass and are sold by Vintage Vee Dub Supplies and are called Aero Look and were designed by Richard Holzl, they feature early Beetle headlight buckets so 911 headlights drop in. Paint colour is blood orange a Porsche colour. A gold Bee Sting radio antenna is fitted at the rear of the roof.
Chassis:
Chassis is from a 1972 Superbug, the chassis was changed to take advantage of more favourable NSW RMS laws for pre 73 model cars. To get better weight distribution the transmission has been moved forward 4 inches. This required the torsion bar housing to be removed; it has been replaced with substantial reinforcing using 1 1/2 roll cage tubing. The brakes master cylinder has been moved sideways to allow room a hydraulic clutch master cylinder to be fitted next to it.
Transmission:
A Porsche G50 5speed transmission from a 1987 Porsche Carrera, a Quaife differential is fitted. CVs are from a Porsche 930 turbo with Swayaway axles. It uses the standard VW mounting point with a Subaru Gears cross member and WRX engine mounts, in the centre of the transmission is a Berg style mount using rubber mountings from a Kombi transmission mounting. At the front of the transmission the original Porsche G50 cross mounting is used. Clutch is a 240 mm aluminium made by Kennedy with a NPC clutch plate. Adaptor plate and flywheel also made by Kennedy.
Engine:
The motor is a EJ207 (2 litre) from a 2003 Subaru WRX STI and had only travelled 13,000 klms when fitted, it has been bored and stroked using a 2.5 Subaru crank, Argo rods and Manley pistons, etc making it 2165cc, it uses Adaptronic Modular engine management, a GM flex fuel sensor is fitted allowing the motor run on any mixture of 98 or E85 via ID2000 injectors. An in tank Walbro 460 feeds another Walbro 460 in a surge tank. Factory headers have been ported and Grimmspeed cross pipe and up pipe are used. The 3 inch exhaust system was built by Westside mufflers, the GTX30/76 has been lifted up higher in the engine bay. Turbo and draws air via hole in the right rear mudguard. Tomei Pon Cams have been fitted as well. A 6x10 PWR water to air intercooler is used and a PWR intercooler radiator is fitted at the front of the car along with its own cooling fan, fluid is pumped to the intercooler radiator with a 12 volt pump, it also has provision to put ice into the system to combat heat soak via a Frozen Boost reservoir, at a recent ½ mile racing event I was leaving the line with 38 degrees C temps out of the turbo and 18 degrees C going into the motor, after returning to the pits there was still ice in the system, turbo outlet temp was 90 degrees C and 22 degrees C going into the motor at end of the ½ mile. It is producing 382 rwkW with more to come @ the wheels on 31 psi on United pump E85.
Rear suspension:
The rear suspension is from a 1986 944 Porsche, it uses similar trailing arms to a Beetle but they are aluminium instead of steel, when used in conjunction with Porsche 944 spring plates they have adjustable height, toe and camber. The mounting points are the same on a Beetle as they are on the Porsche 944. The rear shocks are Bilstein. Short 40 hp style 30 mm Sway Away Torsion bar are used
Front suspension:
The front 3 bolt McPherson struts have been modified to feature adjustable lower spring platforms, and smaller diameter 150 pound springs allow the front wheels to have sufficient clearance, Koni Sport shocks from a series 1 RX7 are fitted. Rack and pinion steering from a 1975 1303 Beetle has been fitted.
Brakes:
Brakes are 4 spot Monoblock Brembos from a Porsche Boxster. On the front they attach to the factory VW calliper mounting via a 6061-T651 aluminium square block adaptor and use a Boxster rotors mounted on 944 alloy hubs. The rear brakes use Porsche 944 rotors with the stock internal Porsche drum emergency brake. The rear callipers attach to the factory Porsche calliper mounting via a 6061-T651 aluminium square block adaptor. The brake master cylinder was moved 25 mm to the right side of the car to allow the clutch master cylinder room to fit beside it. A larger 20.6 master cylinder is fitted, no power assistance is required.
Wheels:
Wheels can vary, 15x6 inch Porsche Cookie cutters for drag racing with 205/50x15 Mickey Thompson ET streets and 195/55x15 Goodyears or ½ mile racing, 18 inch Boxster wheels for the street, I also own 18 inch Porsche Hollow Spoke twists and 18 inch Simmons OM wheels. At the moment I’m running Nitto Invo tyres on the street, 225/40 x 18 and 265/35 x 18, very happy with them.
Interior:
Factory dash with some extra gauges, a Spa combined tacho and speedo, the rest of the gauges are VDO coolant temp gauge, oil temp gauge, oil pressure and fuel level. A Turbosmart Eboost 2 controls boost with settings for wet weather etc. Steering wheel is Momo, seats are vintage Recaro Concords. A 6 point IHRA cage is fitted made by Ministry of Fabrication, waiting on final tech inspection.
Performance:
Best ET was 11.803 and best MPH 124.2912.199. MPH suggest that I should get into the 10s, I was having lots of wheel hop issues and ended up breaking a modified Porsche 944 stub axle. The car has competed in the Snowy Mountains 1000 at Cooma Airport in the past and won its class. it won its class with a time of 22.3247 @ 236.7 kph over the standing 1000 metres and finished 50th out 135 cars. I recently ran a ½ mile event at Gunnedah Airport, I won my class and finished 37th out of 80 cars in a time of 19.5 seconds at 231kph with a slipping clutch. Motor is now making 382 rwkW (512 hp) and I’ve run out of turbo, I will leave it alone for a while, maybe.
Previous owner used the car for hill climbs and circuit racing, it first used a 2180 cc air cooled VW motor, later it was fitted with a Mazda 12A rotary from a Group C touring car, and the car achieved many FTDs during its career. In 1983 the car was stripped of all the go fast bits and stored in a garage at Cowan north of Sydney. I was given the car as just about a bare shell in 2002 when the owner moved to the Gold Coast in Queensland but I didn’t start building the car until 2004. The car was given a body off resto in 2009.Body:
Chassis:
Transmission:
Engine:
Rear suspension:
Front suspension:
Brakes:
Wheels:
Interior:
Performance:
Re: Bored and stroked EJ207 1303
Welcome to the forum. You have a very clean, nice looking and very well put together VW also.
- Steve C
Thanks, I can't believe that I've never posted in this part of the forum before, I've been on Shoptalk forums since May 2000.
I used to have a turbo WBX 1302 before this car and I'm building a 56 Beetle on bags now
Steve, long time no speak. Your car is amazing. I have a question however. In your post, you mention using 15x6 wheels for drag days. I tried a set of REAR Boxster calipers on the front of my 1303 and only I could only get one set of 15 inch wheels to clear the calipers...the red alloy Porsche space saver spares. What wheels are you using for drag days?
John List (aka H20SB)
Sorry I didn't notice the date of joining and the number of posts. Anyway, your bug is still PDN (pretty darn nice
What is the '56 going to be used for? What updates are you planning on?
Steve, what an excellent car.
Were the lower rear shock bolts you talked about elsewhere for this car or the '56?
- Steve C
Thanks JohnH2OSB wrote: ↑Sat Jun 25, 2022 7:34 am Steve, long time no speak. Your car is amazing. I have a question however. In your post, you mention using 15x6 wheels for drag days. I tried a set of REAR Boxster calipers on the front of my 1303 and only I could only get one set of 15 inch wheels to clear the calipers...the red alloy Porsche space saver spares. What wheels are you using for drag days?
Its been 8 years since I met you in So Cal, I hope to return one day.
I had my rear Cookies widened to 8.25 by fitting an internal band, the outer edge of the tyre was pretty flush with the mudguard thanks to the 944 rear trailing arms.
My rear brakes are mounted on aluminium blocks, I had them made a tad thinner which moved the caliper in a bit plus I run some thin slip in spacers and the same on the front I'm running 1/2 inch bolt on spacer.
I had the rear wheels widened to 8.25 when I went from a 205 x 15 Mickey Thompson tyre to 245 M&H
Cheers Steve
- Steve C
Thanks LeeOl'fogasaurus wrote: ↑Sat Jun 25, 2022 9:00 am Sorry I didn't notice the date of joining and the number of posts. Anyway, your bug is still PDN (pretty darn nice)!
The 56 will be a cruiser, pretty stock 1600 for now but later on I will fit the a 1904 from my sons bug, it has 1.4 rockers, Berg 309 cam, twin 40 mm Dells etc. Car has been painted in Capri Blue, waiting for me put it back together.
My son and I are in the Japanese cars scene as well, he is very good at drifting, me I'm learning. My son collects rare Japanese wheels. As soon as I bought the oval we put our heads together to see what wheels would fit. We came up with some Epsilon Southern Ways mesh, I've had them restored already, diamond cut face. I had to convert the car to 114.3 stud pattern
I have a Toyota JZX110 (too nice to drift) and my son and I are building an old Toyota Corona with 2.7 Hi Lux motor a 2RZ that will be sort of disposable in case I stuff up
Cheers Steve
- Steve C
Hi IanIan Godfrey wrote: ↑Sat Jun 25, 2022 5:57 pm Steve, what an excellent car.
Shock bolts are for the orange car. I'm running Baja rear Bilsteins that I think are too soft causing wheel hop. The reason I think that they are too soft is that I had to lay my shocks forward to clear my axles as my motor and trans are 4 inches forward which moves the axles closer to the shock, I think this fact makes them softer so I want to get some better socks that I can adjust,maybe QA1
BTW the narrowed beam and rear bag setuop on my oval came from Skinned Knuckles down your way.
Cheers Steve
Axle wrap (the axle twisting then releasing due to load and wheel drag on the ground for example) can also cause wheel hop ("dancing"). Is there a different size (dia.) or material (strength) axle to take the additional loading? This may not be an answer but might be worth looking into.
Also, the shock's angle can affect this also as well as the shock being too soft. It's hard to tell from the pix (not 3-D) but it does look a bit short and with the mount looking like it is set differently (close to under the axle). Geometry can affect a lot of things; e.g. cause and affect (effect maybe also).
Steve, your shocks do lay over a fair bit. I'm also looking at QA1's for my Karmann with 944 rear arms. The dual adjustable's with uniballs look good and there is a dealer in Sydney who might be able to do some valving to get them close. I imagine there is quite a bit of weight over the rear even with the gear box moving forward!
- Steve C
Hi
I've changed shocks again since that photo. I need to go back and reconsider what I'm doing with this setup, I only used to get minor wheel hop, I've made the mistake of changing too many things. I still have my ET streets that I was running in this video.
I've put a link to a Youtube video https://youtu.be/uhgVgzf5oD0 running a lot less power then, around 280rwkW I think
Cheers Steve
Cheers Steve
- Steve C
Hi IanIan Godfrey wrote: ↑Mon Jun 27, 2022 2:27 am Steve, your shocks do lay over a fair bit. I'm also looking at QA1's for my Karmann with 944 rear arms. The dual adjustable's with uniballs look good and there is a dealer in Sydney who might be able to do some valving to get them close. I imagine there is quite a bit of weight over the rear even with the gear box moving forward!
Is there a dealer in Sydney, I could only find one in Melbourne. I need to measure my shock lengths ad have a talk with them.
Cheers Steve
Steve, I had a look at that video at 1/4 speed, it pretty much squats and goes. If you could get the car to do that with the new set up that would be great. Does the gearbox have a LSD or an ATB.
the Sydney QA1 dealer I was thinking of is https://www.pluckasracecraft.com.au
hopefully still in business.
- Steve C
Thanks for that. I'm running a Quaife, if I could get it to hook up like that again it would really bring down my 60ft
