Planning my MS
Re: Planning my MS
Still haven't gotten this issue sorted out. I talked to Mario this week about sending it to him. He's pretty swamped right now, so I'm holding off until July.
The call I'm really waiting for is Dave Kawell to tell me my new engine is ready.
Re: Planning my MS
Engine is in and running great. Haven't used a distributor in years. ECU is out and at Marios for a little attention.
Re: Planning my MS
I got my ECU back from Mario and installed. Will run ignition only until the fall. I had a bad synch loss starting at 1400rpm, tracked it down to my settings.
I remember when I first got into VW’s how clean dual carbs and an electric fuel pump made the engine. Now we ditch the distributor too. The left coils have to be cocked with these carbs, but will be straight with the throttle bodies.
- panel
Re: Planning my MS
Looks clean in there S_Mitchell ! Is that a ground strap off the wing nut ? Left carb ?
Re: Planning my MS
Good eye panel, it's a makeshift ground from the coils.
Re: Planning my MS
Got my carbs off and throttle bodies on a couple of weeks ago. Have to move my coils to clear the air filters, have an easy idea for that. Fired up first try and seems to run great. Oxygen sensor wasn't working and I tracked it down to a bad ground/solder joint. Finally time to get tuning!
Re: Planning my MS
Here's the video. https://youtu.be/exigoDOIeqg
- brewsy
Re: Planning my MS
Nice one.
Good holidays present to yourself!!!
Marc
Re: Planning my MS
This thing is really running great. I’ve created a very safe map with VEAL. Want to start working on lean cruise settings. Still have to move my coils and tidy up a bit.
- panel
Re: Planning my MS
They (coils) look ok there , no ?
Re: Planning my MS
They interfere with the air cleaners, only moving them inboard a couple of inches.
Re: Planning my MS
It only took two years, but I finally got around to moving my coils. I measured wrong somewhere, so one is about 1" off from being centered.
Re: Planning my MS
I decided to add idle control and found C16 was fried when I pulled the board. I don't know what circuit it is in, but the car has been running fine. I found that this is rare, but not uncommon. They changed to a higher duty capacitor sometime after I bought this board. A new HD one is on the way.
Re: Planning my MS
Oooh, that’s properly fried.
