Newbie with 915
R2.0
Re: Newbie with 915
Post by R2.0 »
Piledriver wrote: Tue Sep 14, 2021 10:03 pm ... If there was room I'd consider adapting a modern cable shifter...
Here's a Cable Shifter in a 914.
1972 Karmann Ghia Convertible
"As God is my witness I though turkeys could fly." - A. Carlson -
Bruce.m
Re: Newbie with 915
Post by Bruce.m »
Hopefully you haven’t filled it up with the blue snake oil?
It makes a 915 worse, not better. Too slippery.
Clatter
Re: Newbie with 915
Post by Clatter »
Bruce.m wrote: Wed Sep 15, 2021 9:32 am Hopefully you haven’t filled it up with the blue snake oil?
An excellent idea, Bruce.
I used Swepco 201 because all of the Porschefiles sing it's praises.
Wonder if some synthetic might be in order?
Thanks for the input gentlemen.
Guess i should put another 8-10 thousand miles on..
Break it in, and give me some practice.
The more i study up, the more i learn that it's just kind of how it is.
With Porsches typically being such an integral part of their owner's ego,
Few will admit the truth. :roll:
Bruce.m
Re: Newbie with 915
Post by Bruce.m »
Have a search/lurk at DDK-online forum. Google is blocked from crawling through the site so it’s less well known. Available via Tapatalk
Clatter
Re: Newbie with 915
Post by Clatter »
R2.0 wrote: Wed Sep 15, 2021 8:23 am
^^Wonder how that actually shifts^^
While it's certainly a cool bit of engineering/fab,
I'd be -real- interested in trying it out, if y'know what i mean.. :wink:
Bruce.m
Re: Newbie with 915
Post by Bruce.m »
Recent discussion on 915 oil.
Guy with 365 fitted with 915, not liking the shifting.
Building muscles with my 915 shift ht ... source=app
Re: Newbie with 915
I know its been done on a 914, and may go there if I use a std 914/901.
... but the discussion is about a T3...With a 723 trans swap. Bit different animal.
The mechanics seem doable though, one cable push/pull, one to rotate.
Possibly better action than the off axis monkey motion shift rod setup seen on most 901/915 trans installs.
I do use such a setup on a regular basis, exept it's in a mk4 tdi...
R2.0
Re: Newbie with 915
Post by R2.0 »
Piledriver wrote: Wed Sep 15, 2021 2:14 pm
I submitted it as more proof of concept. I bookmarked that page for reference when I started thinking about putting a 901 in my Ghia. Now I've decided on a Bug@5speed setup.
When I can find a 914 tail shifter cheap. :lol:
Clatter
Re: Newbie with 915
Post by Clatter »
Bruce.m wrote: Wed Sep 15, 2021 11:35 am Recent discussion on 915 oil.
Aigh.. Link no workie..
Can you fix it please, sir?
Clatter
Re: Newbie with 915
Post by Clatter »
R2.0 wrote: Wed Sep 15, 2021 2:23 pm
I wouldn't be too excited to put a Porsche trans in anything.
They shift like total crap. :x
R2.0
Re: Newbie with 915
Post by R2.0 »
Clatter wrote: Thu Sep 16, 2021 9:16 am
I've driven a 914 - just takes some getting used to.
And that sweet, sweet off-the-H first gear. :lol:
Clatter
Re: Newbie with 915
Post by Clatter »
It would be easy to blame my linkage..
Wanted to keep the shifter over close to the driver's side like a proper type 3.
Also needed to correct a misalignment of the shift rod in the up/down plane a bit too.
Used two mil-spec sealed steering joints - like Jake did on a 915 trans in his bus - one at the nose cone and another in the tunnel.
This meant i had to run two shift rod bushings; one at the shifter and another factory bush aft.
it all moves very tight, sweet and smoothly. FWIW. Maybe some stiction when loaded?
I always am quick to blame anything i touched first, have no doubt..
It's not that it's hard to shift in that it takes effort to move the shifter,
It's just super vague where 3rd gear is between 1st and 5th..
Or where 4th is when coming down from 5th.. It's like it's nowhere to be found.
Bruce.m
Re: Newbie with 915
Post by Bruce.m »
Sorry. It’s a Tapatalk link.
Here is the web browser version :
https://www.ddk-online.com/phpBB2/view ... hp?t=68999
Clatter
Re: Newbie with 915
Post by Clatter »
Bruce.m wrote: Thu Sep 16, 2021 10:52 am
Wow! Sure does make sense for what I'm seeing here.
And here i thought Swepco 201 was just the go-to default for every old Porsche box..
Check this out...
They say a couple of times how this oil isn't too slippery,
So the synchros can grab and work.
https://www.pelicanparts.com/More_Info/ ... &DID=55814
*sigh*
https://www.pelicanparts.com/cgi-bin/su ... m%23item21
Bruce2
Re: Newbie with 915
Post by Bruce2 »
I had a 915 equipped 911SC for a short while. Having never driven any other cars, I thought there must be something wrong with the trans, that it must have been worn out. The shifting was really vague. It also could not be speed shifted like a VW.
When I went to sell it, one of the guys that test drove it made a comment about how great the trans in my car was, that it was so much better than other cars he looked at.
The car was really slow, even though the engine ran good. The leakdown test was good. It was a mystery to me why it was so low on power. Then I read the test results from its year in R&T or C&D. It was mid 16s in the quarter, so there was nothing wrong with my car, they are just SLOW. I had way more fun driving my Beetle, so I dumped that car fast.
It wasn't until 1987 that Porsche finally gave up on their own design crappy synchros and switched over to the Borg Warner synchros that all other cars use. Including VW.
This is why I think it is foolish to install an old Porsche 5 speed in a VW. It takes a ton of work and the results are worse than stock.
If you are willing to do that much work, start with a late model trans from a Subaru and install the conversion R&P. If you get a trans new enough, (after about 06-08) you will get the latest dual cone synchros on 1st thru 3rd gears. Also, a synchro on reverse! The only downside is that the Subaru trans is about 20-30lbs heavier. I bet a 915 trans is about the same, so the point is moot.
