Mid engine 66 bug subaru powered
Re: Mid engine 66 bug subaru powered
How do you plan on supporting the trans mount? The stock trans mount you are connected to by some tubes already has a rep for doing the "dance of death" which is why Kaffer/Truss/Traction Bars are added.
maurice
Post by maurice »
Good observation. There is actually very little weight supported by the frame horns. The majority of it is under the rear of the engine. That part is supported by a large and well supported 1/4” plate. The engine essentially leverages the tranny up, so there’s maybe 70lbs of weight supported between the two frame horns (more with the sti tranny). I plan to mount a wing off of the tube near the tranny, so the horns will get stressed more, but still far less than the weight of an engine hanging off the end of them like in the stock setup.
The structure is also now a rectangle since it’s bolted all together with the round structure on top of it. So twisting the two frame horns would also require the round tubing to also twist.
They’re mostly there for stability, but also provide a solid support should I happen to stress the mount
Since my rig is set up to do different things I look at things differently too. I'm fighting the same area on the rear of the car myself.
maurice
Post by maurice »
I definitely had to stabilize that part of the car with the turbo engine and vw tranny. It’s an issue, but can also be solved with a hydraulic clutch
maurice
Post by maurice »
Not the prettiest job, but everything is removable now! Should be easy to get the engine in and out now
maurice
Post by maurice »
Rolled it around the neighborhood a bit yesterday. Only did low speed stuff, but no understeer when I put my foot in it around a corner. Tranny doesn’t like to shift well, might need to modify my shifter linkage a tiny bit. Suspension might be on the stuff side, I’ll have to start playing with the adjustments and maybe lose the sway bar
Then I can start working on under car aero stuff, and sealing off the engine from the occupants.
kdf
Post by kdf »
I think you should do a basic calculation to verify suspension loads. The inner and outer joint rod end in bending look off.
I have used 10 % load for spherical bearing axial load, but only used quality spherical bearings. In rod end calculation you should also take into consideration how much the rod end can take bending. The strength of the rod end depends on how much rod end is sticking out.
In production cars calculated loads are in the ballpark of 5g bump, 4g longitudinal and 3g lateral. In prototype cars it is less.
maurice
Post by maurice »
I couldn’t really find stickout numbers for the threaded part, but the heim joints are rated to 28,090lbs static load each, which at 10% for all 4 translates to 11,236lbs for axial load.
The entire car weighs 2000lbs, so even if the rear had 75% of the weight on it, the working static limit would be 7.5g’s. I know that that static load and a load I experience while driving wouldn’t be the same, but I don’t think my tires could handle that kinda load and grip.
maurice
Post by maurice »
Since I can’t make it to any car shows, I figure I’d show it off on the interwebs.
maurice
Post by maurice »
Walk around
https://m.youtube.com/watch?v=Wpywnk6JpcY
Video of my nitrous testing, speedo is off 75mph = 65 actual
https://m.youtube.com/watch?v=9M1sh1x-nMI
maurice
Post by maurice »
panel
Post by panel »
Nice with the ear protection on !
panel
Post by panel »
Can't remember if you told us but where did you get the shifting device/mount and cables etc ?
maurice
Post by maurice »
Shifter is from an rsx I got in the junk yard. Mr2’s and all Honda Accord’s (manual of course) use cable shifters.
The cables are push pull ones I got from Kartek off road, I got the 3” travel ones, but they actually caused me some issues mounting them onto my shifter, and I really should have gone with 2” cables. The rest of the linkage and brackets I made myself.
maurice
Post by maurice »
It had a couple really minor issues after those doughnuts. And after another few hundred miles, ended up being a couple spun rods. I totally oil starved.
I’ll rebuild this one again with a killer b setup. And keep building my next engine too
