Tach signal
Booky
Tach signal
Post by Booky »
What do you have to do to use a standard coil for tach signal for fuel only Microsquirt?
ps2375
Re: Tach signal
Post by ps2375 »
Connect it to the coil.
By "standard Tach", do you men a tach that is driven by coil voltage or by a 12vdc square wave signal? What are you using to give the microsquirt an rpm signal, connect tach to that.
Booky
Re: Tach signal
Post by Booky »
Did not probably word it properly.How do you use the coil to generate a signal for fuel injection only on Microsquirt?
Re: Tach signal
https://www.bing.com/search?q=microsqui ... d7820d9104
There are several answers here, maybe one of them will work.
Booky
Re: Tach signal
Post by Booky »
Thanks
Jamesl
Re: Tach signal
Post by Jamesl »
I know this is an old thread, but thought I would provide an answer... You can use a coil to generate a tach signal for fuel only by triggering off the coil negative.
