Gas Heater for a "67 bug
Here's the place to start. Introduce yourself and your ride.
landrocket
Post by landrocket » Fri Oct 16, 2009 10:11 pm
Got our first taste of cold in Denver and want to know who is running gas heaters. Worth it? Easy to install? Any info is appreciated. I have only seen pics, never one up close. It looks like the exhaust is just blowing around next to the gas tank? Yes? Safe? Thx. Ron
Stray Catalyst
Re: Gas Heater for a "67 bug
Post by Stray Catalyst » Sat Oct 17, 2009 7:36 am
I have no actual experience with them - but I've never heard of them being any more prone to fires than the rest of the VW bug. If you're going to get one, buy one of the name brands or an original - they're often posted on Samba.
Stray
Bugfuel
Post by Bugfuel » Sat Oct 17, 2009 10:43 am
I have used them for decades, different models and brands. There is no better way to get heat in a VW!
Absolutely love them, and if you install them properly, they are safe. All of them have failsafe systems and automatic shutoffs.
Exhaust is routed into the driver's side fenderwell, outside of the car. You can run an exhaust piupe extension all the way to the floorpan height. Some models are picky about having ~equal lenght intake and exhaust pipes to maintain proper airflow.
Some glow plug models are getting hard to find, see if you can find spares for the model you are intending to buy, before making your decision.
My favorite is the Eberspacher BN4, one with both glow and spark plugs, and a thermostat to adjust output heat. They are BIG, so they don't fit in the B2/BN2 location by the gas tank. I managed to fit a BN4 in the spare tire well in my 68.
Pay attention to wiring. Do quality work, and wire them exactly as instructed, and use heavy gauge +12V wire to feed it. They draw a lot of power while starting.
landrocket
Post by landrocket » Sat Oct 17, 2009 9:04 pm
Thanks for the info, Ron
Turbinepowered
Post by Turbinepowered » Sun Oct 18, 2009 2:50 pm
How big of an impact do they have on fuel economy, out of curiousity?
Post by david58 » Sun Oct 18, 2009 3:22 pm
Bugfuel
Post by Bugfuel » Mon Oct 19, 2009 6:32 am
Turbinepowered wrote:How big of an impact do they have on fuel economy, out of curiousity?
They burn half a pint to a pint an hour or so?
kangaboy
Post by kangaboy » Thu Oct 22, 2009 6:23 pm
sooooo.....like in gallons?
Turbinepowered
Post by Turbinepowered » Fri Oct 23, 2009 12:57 am
Well, with 8 pints to a gallon, looks like you'd burn an extra gallon or two over the course of a long trip. Not bad, honestly.
spencer.adams
Post by spencer.adams » Wed Feb 26, 2014 12:11 pm
What are some of the brand names making these? Are they still being made? Does anyone have an Eberspacher BN4 for sale? I wondering with all the new stuff I've seen with people restoring components, is there any small business out there rebuilding these or others like them? Thanks
spencer.adams
Post by spencer.adams » Sun Mar 09, 2014 6:48 am
Idid find one person on Samba restoring the Eberspacher's in Denver, CO. If you search for Eberspacher heater on Samba it will take you right to the adds. I plan on looing into one for my 67 Sunroof Beetle. Not freezing cold here on hte VA coast, but the winters do get a little chilly.
odette
Post by odette » Sun Dec 23, 2018 8:07 pm
I had a 1969 VW Mini Rolls and it had a Borg & Warner gas heater. I loved it especially in our sub-zero temps in the upper midwest. The car was toasty warm within minutes of turning on the heater. My 1963 with stock heat was like sitting in a freezer once it got to 20 degrees. Looking for my next VW Beetle and it will have to have a gas heater.
Steve Arndt
Post by Steve Arndt » Mon Dec 24, 2018 11:40 am
I've used them for over 20 years in my bugs. Only way to go with real heavy winter use.
The exhaust pipe runs in the inner fender down towards ground.
V8Nate
Post by V8Nate » Mon Dec 24, 2018 12:32 pm
I put an early bn4 in my bug and it works great! I did however have to modify the heater outlet to fit in the nose but well worth it for almost instant heat:)Image
sideshow
Post by sideshow » Mon Dec 24, 2018 12:50 pm
I suspect “modern fuel” would dissolve, swap meet OEM units if they were not all ways missing metering pumps, fittings, and harness. Has anybody searched the usual retailers for “12v gasoline air heater” and been brave enough to try something like?
http://www.car-parkingheater.com/
Cost wise it doesn’t seem bad. Who is brave enough to try?
