Turbo Gallery
Re: Turbo Gallery
Went back to the single turbo. I know the throttle body is bigger that it need to be but I have it already laying around
- Chip Birks
Re: Turbo Gallery
I didn't know that you knew how to do one turbo! Have you noticed much of a difference yet? How'd you do at the track last night?
Re: Turbo Gallery
whats temps like with the turbo in the engine bay?
- Kalle
Re: Turbo Gallery
Talking of Ghias and turbo. This is a 400hp 1641ccm - 9 second engine. 044 heads, original non counterweighted crank, FK89, H beam rods, E85, PE 6266 turbo and a heck load of boost:
And the proof:
http://www.youtube.com/watch?v=MCDQ28HLFMQ
-BB-
And the proof:
-BB-
- yvre
Re: Turbo Gallery
How the hell does this thing stay together???
- Kalle
Re: Turbo Gallery
yvre wrote:How the hell does this thing stay together???
Do you see all the nuts along side the top of the engine block? There are a few more of them on the underside as well and they keep the block together. If you look closely you can also see the 5 studs holding the heads connected to the case. There are 3 more of them that you cant see. They make sure that the heads do not leave the case.
Let me know if you want more info on how these dam things work.
With a smile
-BB-
- Chip Birks
Re: Turbo Gallery
Kalle wrote:yvre wrote:How the hell does this thing stay together???
With a smile![]()
-BB-
I love that car!
- yvre
Re: Turbo Gallery
With a smile![]()
-BB-
I knew it could only be some old super secret scandinavian trick!
Re: Turbo Gallery
I don't thing there is much differance but is does not have as much cool factor. I ran this same throttle body with this cam FK-44 on 112 lobe with the twins on the yellow bug and ran the same times.Chip Birks wrote:I didn't know that you knew how to do one turbo! Have you noticed much of a difference yet? How'd you do at the track last night?
I did a 7.2something at 97 mph Last week at Piedmont on pump gas with 18-19 psi
Re: Turbo Gallery
To much work to R&R and extra lines. I can get everything out not as a complete package. I still have them, I am sure they will be back sometime
- joosep
- kubelguy13
Re: Turbo Gallery
Looks good Heinz.
"Being ready is not what matters. What matters is winning after you get there."
Re: Turbo Gallery
Joosep, I love the stance of your bug. I would just go all gray primer and take on all challengers.
1973 Karmann Ghia
Turbocharged, Fuel Injected, and Fast!
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270
