Hi all
I recently bought an original VW294B tool and don't know if it's complete as I don't retrieve the correct length of the stud that I had on the Bugpack plastic plate jig.
BP plastic Stud length available:
99mm, 105.5mm with plastic spacer, 111mm with plastic spacer reversed and 116mm with stud reversed no plastic spacer.
Original VWtool:
99mm and 116mm with reversed stud.
Lengths are correct ?
Do I need to make a spacer to have the same length as the plastic jig and what length to which trans?
Any other advises ?
Thanks a lot.
Pat
VW294B tool
- dunegoon
Re: VW294B tool
I have this tool and could probably help you. But, I'm not sure what the heck you are asking me to measure. Reddit has a forum "Explain it like I'm 5" I think you need to get it down to my level
I don't have any plastic thingie in my kit.
