seeking info for DIY Intake manifold design for gsxr TB
- grelland
Re: seeking info for DIY Intake manifold design for gsxr TB
I second that, I also have 185cc injectors on my 1835cc 100-120hp no problems, max duty cycle in the 60% range
Cool thanks guys, I'm aiming for 150bhp so should be fine
If in the future I go turbo I can just swap them for the upper injectors if needs be
supa do you have a part # for these and do they seal tightsupaninja wrote:The spigot flanges got delivered today. ID is just shy of 41mm.
- supaninja
Mikuni KHS-004
No problem with them sealing, since I am using bolt plates I did not have to "stretch" them to fit.
viewtopic.php?f=14&t=140387
What's cracking then?
well, got my manifolds, i'm thinking i'll trim down the manifolds till the the spacing is correct and try that option....
any reason not to? will they still fit the engine ok you think?
pics later!
pics later!
- supaninja
Good luck Andy, post some pics!
will do buddy!
- juki48
nice trim job. weld, or have someone weld, a short tube to the top of each one so you can use a short piece of silicone and band clamps.
Riley
74 Ghia 2276 Turbo MSII Extra
67 Beetle in restoration
Manx Style buggy 1600 stock
yeah thats a pretty good idea, would only need to be an inch or so will measure up and see what it comes at
or i'm tempted to have the flanges welded back on...
Silicon bronze TIG or gas weld them on.
(just make certain you like the aim)
http://www.ebay.co.uk/itm/Metal-Alloy-A ... 3f10f73c3e
was thinking that, could get two out of one as both ends are swedged, and get that brazed/tig's on then short silicone joiner and nice clamps would look ok!
you mean injector aim?
