LSD differential to 091?
- joosep
what would be the cheapest way to get it? are they factory made in some boxes? what year box I should look for it?
- fastback
Re: LSD differential to 091?
you can use the LSD from the 094 tranny . T3 buses. 80-91 2wd
just get it with the bearings/adjusters
- joosep
They are not all with lsd right?
Thanks
Thanks
- fastback
No. You must check tranny code.
They were installed by VW. The only Bus 091 gearbox code I have seen is AAS. I'm sure there are others.
Here's a diff:
http://www.thesamba.com/vw/classifieds/ ... id=1397127
Here's a diff:
