I am almost ready to start building my new 1745cc type 1 engine, and I am going to use the Mofoco hydraulic lifters in it. Their kit didn't come with any instructions
From what I have read, Roy has recomended a 30mm oil pump and 20w-50 oil with this kit in the past. This seems a bit much just for hydro lifters, so......
I was wondering what you guys would think of running a 26mm pump vs. a 30mm for hydro lifters?
For some more back ground, here is what I am doing/thinking on this endeavor so far:
Good used case with lifter bores re-sleeved and slotted, fitted to lifters
Super tight oil pickup tube (couldn't get it out of case)
Hoover HVX mods
Blueprinted, o-ringed oil pump, with gear lash checked, nice tight endplay, drive shaft length adjusted for proper tang engagement
Cast iron full flow oil pump cover, flatness checked/adjusted
5w-30 or 10w-30 motor oil
valve adjustment preload: 1/2 to 3/4 turn past zero
Can anyone think of anything else i should be doing?
Thank you for your help
