Fixxor...I know I'm a PITA...It's what I do.fixxor wrote: And here is what I have done. I am pretty sure the cage is done. Need to do some more stuff to the front and then the inside can be painted. Need to make bumper mounts/skid plates though.
- The firewall is good, but needs to extend to the body on both sides. This could easily be done with strips that attach to the body or to the firewall.
A pillars should be nice and strong with no door sag.fixxor wrote:
In this pic, the hole for access to the clutch tube, etc. is handy if it ever breaks loose (again?), but makes the tunnel VERY likely to break there. I have a friend whose mostly street Baja is broken nearly in half there for that same hole. He has that pan out in the back 40 due to the damage and the body on a different pan.
You're doing nice work. In the end, it should be a nice Class 11 racer!fixxor wrote:
