Devastator wrote:I haven't had a swingaxle apart in several years, so I'm working form memory here.
The only time I remember having that problem, I had put the wrong drums on. It seems to me that you can put the spacers on backwards and have the same thing happen.
Sorry my memory isn't better.
dark_gap wrote:Can the fulcrum plates drop in if I didn't remove the retaining circlip?
No. Probably not the problem then.
So, you removed the assembly from the transaxle at the side cover, but you only replaced the outside bearing cover, (against the backing plate)?
Well, actually I have change the side cover, the gaskets, all the nuts and studs, the outside oil seal, o-rings.
If isn't the fulcrum plates (cause I didn't disassemble them) and if there is only one shim after the bearing...it must be the new EMPI Side Bearing Cover, this one:
Anybody knows if they have different heigh than originals? Cause I have use all the stuff I have remove and it can be possible that the lenght of the axle shaft have increased about one centimetre.
dangerous wrote:Looks like the spacer between the axle shoulder and the bearing has been left out.
It IS possible that the fulcrum plates have slipped down behind the axle's end,
but to protrude as far as yours,
the 4-bolt bearing retainer must not have seated down correctly.
Either wat you must disassemble to find the problem.
Hi dangerous,
Tomorrow I will disassemble all again to protrude, Can the inner spacer slip inside the axle shaft? Cause I replace the axle tube outside the axle shaft and then replace the inner spacer - bearing - Oring - shim - small oring - backplate - gasket - oil seal - shim - bearing retainer and then I have tighten the four bolts with an impact gun.
I'm so lost because I spend so much time rebuilding the axle with the Haynes book and then I'm so stuck...newbie problems I think
Thank you mates!!
