bad sounds, axle play
- fusername
So I have a swing axle ~67 fiberglass buggy, and suddenly it developed a real not nice sound from the drivers rear axle. When I am coasting real slow (5-10 mph) and in or out of gear, sometimes there is this rythmic clunk clunk clunk like a mallet hitting some steel. IT only happens sometimes, and is more likely to happen if I let off the gas suddenly or blip it quickly, regardless of clutch position. As far as I can tell it never happens at speed. I jacked up that axle expecting loose lugs, and found nothing. I did find I can pull the drum/axle in and out about 1/16-1/18 an inch. It is not the drum on the axle, but the whole kit and kaboodle. Options? Ideas? So far I have heard lunched bearing, although I would expect noise at speed, and wrong axletube/axle combo. been driving for a while and it only started making the noise now, tightening the rear brakes seems to have made it worse, from a clunk to the said mallet on steel sound. its not a nice sound. I have also had it suggested the nut is loose, but she isn't leaking any fluids, but I have it parked either way. I need to borrow the wrench to get the axle nut off, so I want to have a checklist of possible problems before I waste a day on it.
- fusername
Re: bad sounds, axle play
oh I have about 4k on this new transmission, and only got the noise now
- fusername
anyone? hopefully its a bad bearing, but if its axle length mismatch, anyone have a good online reference explaining how much I can id without tearing it all apart?
- fusername
ok I found this, so its a start
http://www.dunebuggyarchives.com/ShortVSLong
I assume if I have SHORT tubes there is no way to put a long axle in by accident as the bearing would seat on the axle too early and you can't get the retainer on, but if i have LONG tubes anything is possible. Are there any other tube lengths, mabye bus or type III that could have accidently ended out on my car?
- Pablo2
Yes, I think you're onto the problem .. either a bad bearing or incorrect bearing retainer would be my first guesses. Either way, you need to start disassembling that side. Please let us know what you find ..
aka Pablo, gears, Geary
9.36 @ 146 in '86
9.36 @ 146 in '86
- fusername
happilly....
- turboblue
I think sedan axle tubes are the same length.fusername wrote:ok I found this, so its a start
Housings are different.
There are 3 axle lengths also.
Your link referred to 67 being a long axle.
US spec '67 had an intermediate axle.
Those cars had a long housing but the shorter splined 5 lug drum.
- fusername
... yay...
- fusername
My German 1974 VW workshop manual lists the following:
Type 1 august 1966- August 1967
* 1358 mm track
* 5 lug
* axle nut w/no shoulder
* bearing cover seating depth 22.5 mm
* ?? axle
Type 1 august 1967- on
* 1350 mm track
* 4 lug
* axle nut with shoulder
* bearing cover seating depth 19.5 MM
* ?? but different axle (has longer splines in diagram, but not stated)
Type 3 From August 1965-on
all same as type 1 from august 67 - on
EXCEPT
different backplate
two piece drum
differnt axle tube
* 1358 mm track
* 5 lug
* ?? axle
* 1350 mm track
* 4 lug
EXCEPT
different backplate
two piece drum
differnt axle tube
- turboblue
German specs are different.fusername wrote:My German 1974 VW workshop manual lists the following:
* 1358 mm track
* 5 lug
* ?? axle
* 1350 mm track
* 4 lug
EXCEPT
different backplate
two piece drum
differnt axle tube
My 67 German Euro spec bug is a 4 lug, long axle.
Three US spec axles AFAIK.
26-11/16ths, short axle, short housing to '66
27-13/16ths intermediate axle, long housing '67
28-7/16ths long axle, long housing '68
Sounds more like the splines in the brake drum are going bad.
- fusername
soooo, after a reassembly I have no noise (for now I am sure) and no leaks (shocking but YAY) so we will see what happens. However I became suspicious of my brake pads, they look very poorly made w/ 1/16 of material hanging over in corners here and there. Also there appears to be some faint "tap" marks on the end of a lug bolt (pulled drum off w/ lugs in still) so I think it is possible that something in the brakes was hitting, HOWEVER I couldn't find any evidence on the internal bits of the brakes. I put it all back together, should the noise return I will use soem dychem and reassemble, and drive till i hear more noise, then check and see if there is any new clues, OR just throw a new set of pads at it, I don't like these.
