The foregoing is an answer from Marc from almost two years ago. It answers a lot, but my situation makes me wonder.... I'm finally reassembling my 1600 dual-port after replacing clutch and push rod tubes.Prior to `70, all cases were single-relief - and there were some newer cases made south of the border which were too.
From here on I'm talkin' US-market:
Through `69, single-relief/8mm oil passages/early-style cooler (non dog-house, 6mm mounting hardware, inside the main shroud with wedding-band style cooler seals; the bottom of the cooler was "flat").
1970 only (B6 case), dual-relief/10mm passages/modified early-style cooler with slight bumps at the three 6mm mounting points to provide clearance for the "flying-saucer" seals (not to be confused with the thicker 8mm seals used on pre`70 Type III). These coolers (P/N 111 117 021E) obsoleted the 111 117 021 flat-bottom coolers so you may find one on an earlier engine if it's ever been replaced. Special seals are needed when doing this (read on).
1971 and up (AE/AH/AK/AJ/etc./etc. cases), dual-relief/10mm passage with 8mm mounting hardware and the "doghouse" cooler. These use the same seals as the `70.
There exist "conversion" seals (usually green in color, rarely grey) which allow the use of a 10mm-passage cooler on an 8mm-passage case and vise-versa. In the unique situation of fitting an early flat-bottom cooler to a later case (yecch!) it's also necessary to put spacer washers at the 3 mounting points to lift the cooler enough to prevent squishing the seals, in all other scenarios the spacer washers are not used.
Obviously, if fitting a doghouse cooler with 8mm mounting hardware to a `70 or earlier case you'll need to drill out the holes in the two case "ears" and replace the 6mm stud with an 8mm (there are sleazier options, I'll not address those right now).
Less-obviously, if fitting an early cooler with 6mm mounting hardware you should furnish a sleeve around at least one of the cooler studs to properly position it over the seals. The 8mm stud in the case doesn't have to be replaced with 6mm (although that's the more elegant way) if you open up the slot in the cooler enough to accept the 8mm stud.
What's the ID number of the case in question?
My question is whether I need the green adaptor oil cooler seals and stud spacers or the orange flying saucer style, I already installed? It had green ones when I took it apart, but then I didn't know they were any different in shape and purpose than the orange ones. It did not have stud spacers "to prevent squishing the seals."
The case number is AB 106393, which I've figured out makes it a 1300 case manufactured roughly October/November of 1970. (Does that make it a '71 model year?) The doghouse cooler seems to be matched to that case, flat on bottom. Installing the cooler over the seals without tightening nuts at all had it resting on the seals raised above the top of the case a smidge and without knowing, since I hadn't read the quoted post yet, I wondered if I should just tighten it down knowing it would squish the seals a little. I went ahead and tightened it down to the case without washers just to see if it would go all the way. Taking it back off, it didn't seem to distort the seals. So I put on the washers and buttoned it up. Now engine tin is on, too.
I know this is a key area for leaking. I believe the cooler is the correct one for that year/size case, but wanted to double check the issue of whether I may have squished the seals beyond normal squish specs. Those previous green seals also make me wonder if indeed I should be using them, because I may, in fact, actually have a "newer" cooler on an "older" case and just not know it. Based on the quoted post and the case number I think everything is okay, but wanted to be sure before I finish putting it all back together and putting it in the buggy.
Thanx,
Barry
