My first Car, Bug and, Build
greenbajamachine
Post by greenbajamachine »
I got a 61 bug with a 1835 dual carb.
This is how i got it
Sold the sand tires got these Wrangler silent armour with kevlar
used her for a little while
This is partial inside
This is my dash and wiring
rear end
Front end
How it sat before i started
I removed the seats carpet most of the tar stuff, cut the cage welds off to remove it and this is what i got
Driver side
Passenger side
rear
shifter front
Cut out the cage
Coverting to irs i bought this tranny and stock boxed arm and jigs
started to remove motor
Got it off
Mounted my other tran fit perfect pic of them together
spring plate
crack in torsion
this was all done yesterday
Big Dave
Re: My first Car, Bug and, Build
Post by Big Dave »
Excellent work and nice car! Looks like you are starting with a good solid car. Keep up the good work.
I don't always show my signature. But when I do, it's in this area.
Whew, all that work in one day? Nice start and nicer work, good job!
TimS
Post by TimS »
Thanks for starting up a build page. Make your self at home and keep updating us with progress and thoughts.
greenbajamachine
eventully ima end up with both but for now should i buy coil overs with spring plate eliminaters or disk brakes?
Last edited by greenbajamachine on Sat Dec 17, 2011 11:23 pm, edited 2 times in total.
TimS
Post by TimS »
greenbajamachine wrote:eventully ima end up with both but for now should i buy coil overs with spring plate eliminaters or disk brakes?
Coilovers. They are harder to setup, mount, etc.
Save the disc brakes for later because they are pretty much a bolt on item.
greenbajamachine
Or a different type of shocks. I also want to make my trailing arms bigger not to sure how or where to cut them.
TimS
Post by TimS »
http://www.shoptalkforums.com/viewtopic ... 8&t=126314
Nilza's build page is a wealth of information for the "do evertyhing yourself"er. He lengthened his own arms about halfway down on page 1.
greenbajamachine
Got my swing axle transmission out. Next taking of body
greenbajamachine
How much are these worth dual solex carb with scat manifolds
greenbajamachine
My Christmas Gift
Chris V
Post by Chris V »
greenbajamachine wrote:How much are these worth dual solex carb with scat manifolds
More importantly those are newer carbs with electric chokes...third-hand market can be a bit rough, but somewhere between 200-400 is reasonable.
greenbajamachine
Thanks for the info now i need to find a buyer.
nilza
Post by nilza »
My ears are burning, ha ha............
Looks like a really great starting point, and a welder for xmas what more could a man want? ( i'm sure herbie will step in with the answer to that)
Am interested to watch your build, good luck
TimS
Post by TimS »
nilza wrote:My ears are burning, ha ha............
Hope you don't mind, I use your build page for reference a LOT!! :D
