They will all require about the same amount of modifications to make them fit so then you need to decide what size TB's you want. I have 38mm's on my 1971cc motor and love them, but they are a 2 yr only size. any of the 06-present 600 (I think 750cc's too) TB's are 40mm. The liter bikes have 42mm TB's, but you will run into a weaker vacuum signal with those(drivability issues).
I know I mention this...a lot
. 44 IDF's only have 36mm venturis plus all that crap in the middle. I wish I had a rig to compare flow between different manifolds, carbs, and TB's. With a street car bigger TB's isn't better.
