WBX crankshaft strenght
Svang1
Post by Svang1 »
- What is a welded 82mm crank with addded counterweights capeable of?
(Of course fully balanced with all components, delivered from either DMS or DPR)
- Is it possible to achieve up to 700hp or more with this crank, for street-use?
(Not a daily driver engine, just for some useless kilometres with to much hp, and some strip driving)
- Is it necessary to wedgemate when 5*12mm flywheel-pattern?
buildabiggerboxer
Re: WBX crankshaft strenght
Post by buildabiggerboxer »
on the basis of all the 400 hp 1641s with stock cranks i keep reading about, i would say you were on a safe bet easily enough, just use ahendorp bolts in the flywheel and away you go....
Svang1
Post by Svang1 »
So you say no wedgemating..
That would be the easiest, and cheapest in order to change the flywheel.. (note: pre-balanced)
But is there any examples of engines with 700+ hp with welded wbx cranks and no wedgemate?
Rolf
Post by Rolf »
700+ hp is ALOT !!! I would say it's beyound what a welded crank can handle. It might take the beating
for a while but I doubt it will live for long. Go for a type 1 flange with all type 4 mains with that kind of
HP and skip the welded, wegde mated, dowel pined crank and flywheel.
If you choose to go for a weled crank it needs all the help it can get to transfer the power to the flywheel.
Go for wegde mating, 5 pc 6 mm dowel pins and super bolts for holding and hope it will stay together for
a while.
/Rolf
Denmark
Svang1
Post by Svang1 »
Thanks for the reply Rolf.
I would not risk the rest of the rather expensive engine with a simple solution as a welded wbx crank,
if it's not "bulletproof"..
So, is really the flanged crank street friendly?
Many different opinions on that subject..
Heads up performance is said to be able to make the flange cope with the thrust,
when mounted brass sides to the bearing.
Anyone with experience of flange+streetuse+to much HP??
Carsten B
Post by Carsten B »
Hi.
There is 600hp Wbx engines running with stock wbx cranks. I really dont know(think) that the crank will be any stronger with counterweights added.
Living in Norway has one BIG advantage... you can call or order from Skinne Racing... :-)
reg Carsten
fastback
Post by fastback »
i really hope the Welded counterweight DPR ones holds up the same OR higher that a stock one.
has anyone broken a stock WBX one yet due to "to much HP"
Svang1
Post by Svang1 »
Sure is important to balance properly.. Done by a professional..
Will the WBX flywheel-pattern hold the horses when flanged??
I wonder what Skinne is using in his current engine..
ajdenette
Post by ajdenette »
Wrong Forum ment for the bus barn :oops:
Alex
|_________oo_oo
/ /__/____[_____\
I I======[]IIIIIII[]
()_)-----()_)----)_)
Rolf
Post by Rolf »
Svang1 wrote:Sure is important to balance properly.. Done by a professional..
A flange crank uses another flywheel bolt pattern at the mounting surface
of the flywheel, it's a big flange. The bolt pattern is larger and uses either 6
or 8 bolts where the WBX/type 4 uses 5 bolts.
A DPR welded WBX crank will allway have the stock WBX flywheel bolt pattern.
I don't know the upper HP limit for welded crank but I have build a 277+
HP normally aspirated oxyboxer and the crank and flywheel are still ok.
Wheel hop and drag slicks are hard on parts including cranks and flywheels.
The problem with a flange crank for street use is that it's not holding up for
a whole lot of engine braking and don't like to have the clutch disengaged for
a long time. The latter was a bigger problem in the past with the split main
bearing behind the flywheel. With the brass thrust rings inserts it's a hole lot
better, but I'm don't know if it's good for lot of real street use.
I think Skinne uses a 86 mm flange crank.
/Rolf
Denmark
Svang1
Post by Svang1 »
Thats the issue..
Best to keep the stock pattern, of course..
But I will not use it if I can't depend on it..
Don Pauter says its no issue at all with flanged crank on street (of course with the supercase).
Already used in his yellow N/A ghia.
But whats the difference in a supercase, that you cant modify/machine on to a WBX case?
Others have said that Roger Crawford is up for the flange-mod with brass supports,
that will hold the amount of horsepower with streetuse for severeal miles..
DORIGTT
Post by DORIGTT »
So am I hearing that you can use a T-1 crank in the WBX case to get a stroker?
fastback
Post by fastback »
or get a stroked wbx crank from DPR :)
