Give mattt a holler, ya Thing peddler.baja5 wrote:No worries, I just picked up a couple of things that have rusty bodies, and are getting turned into more Desert style cars, so i have a bunch of stock stuff to unload.
181 Swap and Sell
- CopperBaja
jeff 9900
1973 thing parts
i just got done restoring my 73 i have many good reusable pieces left over all 4 windows with good frames poor plastic that has been redone,complete top with frame top has holes and the header piece needs to be welded or replaced,almoit all rubber moldings in good shape i just replaced them all cause i could. thats the major stuff let me know if there is any interest in some or all or something i did not mention.
DannyK
Re: 1973 thing parts
What area are you in Jeff? I may want a soft-top frame if you still have it. Thanks.jeff 9900 wrote:i just got done restoring my 73 i have many good reusable pieces left over all 4 windows with good frames poor plastic that has been redone,complete top with frame top has holes and the header piece needs to be welded or replaced,almoit all rubber moldings in good shape i just replaced them all cause i could. thats the major stuff let me know if there is any interest in some or all or something i did not mention.
DannyK
Re:
Do you have a straight driver's side door ?CopperBaja wrote:Give mattt a holler, ya Thing peddler.baja5 wrote:No worries, I just picked up a couple of things that have rusty bodies, and are getting turned into more Desert style cars, so i have a bunch of stock stuff to unload.
- baja5
Re: 181 Swap and Sell
Not that i am selling, sorry. Got a few rear bumpers left, and some safari rear seats, and a stock oil bath air filter. Not much else.
green181
Kubelmann,
I would like to level the stance of my 74 Thing. It is all stock, including the tires, and the back end is lower than the front. I prefer either level or slightly raised in the back. The torsion arms in the back have the spring plates only about 3/8" from the stops, so I'm thinking that going one notch further on the splines would be too close to the stops and still not much lift. What I am thinking is to get some taller 14" tires for my stock 'wide 5' rims. Do you have any recommendation on where to get some? Local Discount tire had nothing.. Thanks
-Green181
-Green181
- david58
Welcome to the STF green181. You could notch your spring plates and keep your tires.green181 wrote:Kubelmann,
-Green181
helowrench
Got somebody that will probably need a front beam, or at least the thing specific trailing arms (does anyone know the pn's ?)
and she is looking for a hard top.
Rob
Rob
- Kubelmann
The Thing beam is 181 400 025 for a 73/74
upper torsion arms are 181405103 (left)
181405 104 (Right)
Lower arms are 181405 151 (left) 181 405 152 (Right)
Note:
When there is a right and left VW part the left part ends in an odd number and the right side ends with an even number
181405 104 (Right)
Note:
- Titaniumxrc
Hi I'm looking for a rear view, and side mirrors, seat belts, visors, and the "VW" emblem for the front.
Jim at:
[email protected]
Thanks
Jim at:
[email protected]
Thanks
Ghia4me
Hello - looking for a "thing" project ---- Father - son deal (mostly father I bet) my 15 yr old son picked a 181 --- after I told him "NO" to 914 - beetle - dune buggy ....... for his first driver (it will be mine ) that he can use ------ in Savannah ga but willing to pick up with in about 500 miles --- nice 2 day road trip with the kid ----- thanks 912-210-017 5 Scott
- Kubelmann
Let the group have some idea about your budget for the project. That might bring more responses. K-mann
- bobsthing
Want a Left hand driver curtain frame to make a toll window and burger friendly screen
BobsThing
- Kubelmann
If you have a bare metal frame, you can turn it into a left or right. I have a local guy who is now recovering bare frames better than new. I do have bare metal frames available.
RWK
I have a rusty thing pan and rusty (between beams) ft beam,(stripped) has rear trailing arms attached. Jack points, battery tray,pedal area out to edge gone, seam rust along dr. seat tracks, and along tunnel, some holes, P.M. for pics, best offer.
RWK
RWK
