BACKGROUND - Studs, Bolts & LugsOR BEST/Hall of Fame Series
This thread series is intended to help you improve your work and reduce headaches. This is a collective project.
VW did a great job of eliminating parts from the cars. Compred to US cars, they eliminated 32-40 parts too many --- studs. If you race, you're not a allowed to use wheel bolts. It is common for Wide 5 rims to pop out the threads.
Not sure about you... I've lost a wheel on the freeway... thank goodness for driving school.
QUESTION - WHEEL Fasteners
Any comments on screw in studs... pull through studs... good ol time bolts?
How do you secure your rims to the drums (or disks)?
If you're a racer, are the low cost stud kits acceptable or is there a fastener grade required?
Why do threads pop out of early wide 5 drums easier?
