My work in progress- 1+ years and counting
Hottarod
Post by Hottarod »
Drug this home. Ugly faded maroon paint, engine was toast, rusted out pans, springs were topped out, brakes totally shot.
Its a late 60's Beecraft built by Bee Craft boats
Built a new 1641 in my back yard, moly counterweighted crank and I beam rods, as41, Kennedy stage 1, 13 lb flywheel,
full flow oil, balanced, new tins, new cooler, moly pushrods, racing lifters, Engle 110, new Mahle pistons and cylinders. billet 1 piece rocker shafts and 1.25 rockers.
Upgraded to an IDF 44 for future turbo. The Pict carb would not run at all and was full of crud.
Couple of months sanding on the body
one of many trial fits with new turn signals and flip up gas cap
new 17 inch rims and some decent meat on the tires and another trial fit
After sandblasting, clean up, new floor pans, primed, painted, undercoated, rebuilt axles/cv's, new shocks, new bumpers, new bushings, roll cage, new shifter, installed front adjusters, new tank bolted to chassis, new seats, new pilot running lights
collecting turbo bits
intercooler pipe and oil lines
bov
carb pressure box and carb bits
K03S Passat 1.8t turbo
I just had an engine catastrophe which broke a rocker arm, bent a valve, bent the valve guide and cracked the head. It should be fixed and going again once the heads are redone. While they are apart I'm porting them for the turbo.
Meanwhile I'm working on my other agony, the mustang.
Yes I am certifiably nuts for restoring 2 vehicles at one time.
Sneaks
Re: My work in progress- 1+ years and counting
Post by Sneaks »
I feel your pain. Nice work so far.
johnbrnrd
Post by johnbrnrd »
can't wait to see them restored. love the work on the buggy, when i multi task its either one fails or both.. lol
