I only have a little bit of time available today for this, so no pics yet, but they're coming.
Earlier I mentioned that I had leveled the frame and found center so I could continue my trailing arm upgrade. Here is how I did it. First I had to decide what I wanted everything to be straight to. For this, I chose the torsion housing. In machining, we have these things called 1-2-3 blocks. They are steel blocks, with or without holes in them, that have been ground to 1 inch x 2 inches x 3 inches, straight, perpendicular, and parallel on all sides. I used 2 of these 1-2-3 blocks and a level to level the torsion housing. I simply zip tied the level to the bottom of the torsion tube with the 1-2-3 blocks between them, and moved my jack stands forward and backwards, (since they are on a slightly angled frame rail), until the level indicated that it was level. Cut the zip ties off an put everything away. To level from front to back, (not as important for a rear trailing arm build), I set the level on the longest bar that goes to the front end and leveled from there.
Next, I had to find the center of the transaxle. At first I considered using the center of the frame, (torsion housing), for the centerline, but changed my mind because I am building trailing arms that must be equidistant from the trans and not the frame, so that the axles will be the same length. To find the transaxle centerline, I bolted up 2 CV joints and suspended plumb bobs from them. I marked these locations on the floor, attached the strings to the CV's and taped them to the floor at the marked points. Now, I simply measured the distance between them and divided by 2. Marked this location on the transaxle. Then I moved to the front end and found the center of it with a similar method. Next, I attached a bar to the rear engine cage and hooked a string line to it. Stretch this to the mark on the front end, making sure I intersected the c/l of the transaxle, and viola, a centerline string. I marked this c/l with a sharpie in several locations for future reference and moved on to the trailing arm end plate fixture.
I'll go into more detail about this fixture when I have the pics for clarity.
Dev
