Here is a little tip I stumbled on today. Looking at the openings in the swing arms, I was wondering what could I do to block off the openings. Since all the old grease was removed and they were nice and clean and dry.....I found Tennis Balls does the trick.....Now when you repaint, the only problem is, your balls won't be yellow anymore.
'72 Standard
"I am the proud owner of a "Hoover Bit".
185 60's, EMPI disc kit, EMPI 2 1/2" dropped spindles on the front.
185 65's and stock binders on the back.
SecondSkin - Damplifier Pro and Luxury Liner Pro for sound control.
