Ninja ZX-12R throttle bodies for my Type IV, getting closer
Mueller
Post by Mueller »
Why couldn't you just use a FI injected manifold?
I thought about, however the transition from the OD of the t/b to the OD of the intake runner is too large a wouldn't flow too well.
This allows me to use more modern fuel injectors as well more easily
What are you drilling?
nothing, that is the endmill used to cut the manifold, I didn't want to remove it since I still have to mill the other flange.
SLICK.
Mueller
Post by Mueller »
here is one mounted on one side of the motor....
I screwed up, these manifolds are for 2.0 3-bolt heads...my motor is a 1.8 with 4-bolt heads, anyone want to buy these?? :)
(2.0 head in picture is thrashed beyond repair and for mock up use)
now to figure out the linkage....
I think you were joking, but just in case, the pictured manifolds have holes for either 3 or 4 bolt heads... (and if they didn't, they easily could)
Mueller
Post by Mueller »
the "outer" holes of the manifold have been filled, so right now, they will only bolt onto a 2.0 head....I'll have to drill new holes, no big deal....I have another set of manifolds in my storage shed, hopefully those are setup for a 1.7/1.8 heads already....
I do plan attempting to sell these since I have 2 complete pairs of manifolds and 2 sets of motorcycle throttle bodies and only need on set.
It's a sweet setup--- I would be first in line if I had a use for them.
I even have 3 bolt heads to stick them on ;-)
M3D
your bike bodys
Post by M3D »
YES this it what i like to see a man with BALLS that we see a job to the end SWEET I LOVE IT
from bug man nrg keep it comming :D :twisted:
www.emeraldperformance.com
your the MAN
Mueller
Post by Mueller »
a little more progress....gonna modify the overlap per "B"
A buddy of mine in So-Cal made the airhorn, pretty cool to see metal spinning is still around and not a complete lost art.
slowtwitch
Post by slowtwitch »
Very nice work :D I've been thinking about using cycle throttle bodies and your work is really motivating me. Have you any thoughts on what type of air filter you will be using???
pete
Mueller
Post by Mueller »
A little bit more progress....
I only have the one length velocity stack to t/b adapter tubes but it wouldn't be that hard to make a few different lengths.
You can see the overlap that I had to deal with, these are not as pretty as they should be, I screwed up and removed about .100" too much from one...no big deal, I'll figure something out
Still struggling with the aircleaner choice, I'll have a better idea once I mock these up on the motor in the car for a clearance check.
Hmmm.. I may need a set of those for my Goldwing>MS conversion.
(I forgot how badly the old girls carbs sucked)
76bug
Post by 76bug »
how are you goin with your throttle body setup Mueller???
Mr. Electric Wizard
Post by Mr. Electric Wizard »
x 2 8)
M3D
itbs
Post by M3D »
if you needs stack give me a call i might have some kicking around the shop
Mueller
Post by Mueller »
progress...ain't it an amazing thing?? hahahaha
All 4 manifolds are machined and the rubber gromments are cut...
next will be linkage and air cleaners....figure another few months at the pace I get things done :shock:
