seal p/n 113 311 113 D
Class 11 streeter
Post by Class 11 streeter »
Anyone know what this is for?
It's from a box of 411 stuff I got off a fellow some time back. The seal itself is about as big around as an old US dollar coin and about 3/4" tall, and has a spring like a crank pulley seal.
Just curious! :D
Glenn
Post by Glenn »
It's a tranny input shaft seal.
Class 11 streeter
Thanks Glenn, you are da man!
Is it 411 specific, or does it go on the T1 style trans?
Post by Marc »
I don't believe I've ever seen a "D" revision input shaft seal (but it's been years since I worked in the trade). The number I'm familiar with is the 113 311 113A, which fits many applications...presumably so does the "D"
http://www.bughaus.com/transaxl.htm
raygreenwood
Post by raygreenwood »
I'll have to pull up the type (004) gear box mainshaft seal number. On a type four 004 four speed, it is specific. It has a different shaft size than types 1-3.
Oh...here it is. 004-311-491A. A standard cross match seal available is CR-6620. The diemensions are 17x30x7mm Ray
