Anyone seen a Bug/Ghia with a Corvette C5/C6 rear cradle mounted to the cage/frame?
The cradle bolts from below, and the geometry is well proven.
The cradle itself needs some narrowing if you want to have a track width of a stock Beetle, but it's aluminum and easy to cut and weld.
Different IRS setups
Boost was created only to make people smile, and make power!
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
Re: Different IRS setups
Your enquiry may get more traction in the "Conversion Perversions" section on this site...
- Jadewombat
If you go that route, I would suggest taking a look at the Project Binky video series on the YouTubes. They grafted a 4WD Celica system into an old Mini Cooper, but most relevant they made specific jigs to transfer the mounting point measurements from one car to the other and cut down on a ton of work trying to keep the geometry correct from one car to the other.
- dstar5000
HECK YEA, SMART THINKING!Jadewombat wrote: ↑Mon Dec 07, 2020 6:38 am ...but most relevant they made specific jigs to transfer the mounting point measurements from one car to the other and cut down on a ton of work trying to keep the geometry correct from one car to the other.
DON
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
