Finally starting on a blow through Kadron motor
- John S.
Re: Finally starting on a blow through Kadron motor
Cool stuff and loads of info. Keep it up
- rubenski
Turbo buggy's rule!!
Good times!
Verstuurd vanaf mijn SM-A515F met Tapatalk
Good times!
- John S.
What brand is that pretty blow off valve?
- buguy
That looks like it would be a blast!
- Lo Cash John
John’s a sharp dude, he watched my LM-2 from the passenger seat when we were tuning. That 1850lb street car went 6.70’s at 102 like a bracket car. Drove it everywhere. He was a very big help.
Good to see you got up and running. But be aware that even 650 outers, being about 30 lbs stronger @ 1" it will barely be enough for the Tcs10 cam at 6000 rpms and even just 9-10 psi boost. That cam needs A LOT of spring pressure.
Hi John, I started buying parts/ mocking up my first turbo kit last week! Only I have a couple questions.... what tube size did you use from the header to the turbo? how would you attach the boost pipes to an ICT carb / carb without screws to attach the filter. are dual 34 ict's big enough for a stock block 1600?
the lower the altitude the higher the attitude ^Aaron Kaufmann^
John is a busy dude from what I can tell. Might be a while before you get a reply. In my own build, I just used the collector tube on a trimill 1.5" baja header. It happened to be slightly smaller than the turbo inlet.mrbugalicious wrote: ↑Wed Apr 28, 2021 11:11 am Hi John, I started buying parts/ mocking up my first turbo kit last week! Only I have a couple questions.... what tube size did you use from the header to the turbo? how would you attach the boost pipes to an ICT carb / carb without screws to attach the filter. are dual 34 ict's big enough for a stock block 1600?
Look up the good ol' clonebug thread. He boosted through a single 34pict3 for a while with good results. Dual ict's should be just fine.
Boosting through solex carbs is a total PITA to tune, but its alot of fun if you like constantly messing with things.
- Lo Cash John
For the K03 we measured the inlet diameter of the turbine (hot side) and came up with something very close to 1-7/8" of an inch so that's what we used. The mandrel bends were ordered from either Summit or www.MandrelBends.com, I can't recall which. Note 1.88" tube is also known as 1-7/8".
Post some pics of the ICT's and we can kick around some ideas on attachments. Someone will have an idea I'm sure.
What are the details of your engine? Is it 100% stock or is it somewhat built up?
As mentioned I work a lot and have way to many projects sucking up my time but I'll reply as much as possible. Plus there are plenty of other VERY SMART guys on this forum.
this is my mock up engine
[IMG_3995.HEIC] IMG_3995.HEIC[/img]
the engine it will go into when finished
the empi 34 ict carbs
enige itself is 100% stock
I was planning on:
K03S -053
oil feed from an CSP oil pump cover with feed for full flow, oil return to right valve cover, stock fuel pump with boost reference, D1 spec pretty 35mmblow off valve, non brand boost controller
i want to run about 7 psi of boost
- Lo Cash John
Your images did not show up. Not sure why so check that.
No need to run the oil feed the way you describe. You can simply add a T fitting where the oil pressure sensor is and get oil from there.
Returning oil to valve cover works well, just make sure you can get it on and off for valve adjustments.
Modded stock pump works awesome, just make sure to close off the vent hole and if necessary the ends of the pivot shaft. I also advise adding an o-ring to the pushrod.
What are you doing for ignition?
EDIT: Pics in prior post visible now.
posted the pics in my last post, I was thinking for ignition either an 123 bluetooth or a CSP pacemaker usb/bluetooth.Lo Cash John wrote: ↑Thu Apr 29, 2021 5:18 am Your images did not show up. Not sure why so check that.
csp is the easiest to get quality parts from as I live in Europe
- rubenski
Indeed, don't take oil from the pump.
Ingition tuning will be as important as fuel tuning!
Ignition tuning will be dependent on intake temps. At 7 lbs. and 90 deg F. inlet temps you will see around 154 degrees F. boosted intake temps without any cooling.
That's getting up there and will give serious detonation without retarding ignition to around 20-22 degrees depending on the engine of course.
