Thanks!
18mm translates to 45/64" or 0.703" which is close to 3/4" (0.75") which is a lot heavier than what things look like in the pix. Since I ride in pretty rough conditions I was more focused on the rod ends but even the top threaded area still bothers me as there is the "easy on" thread design (like nuts have) into the threaded area of the receptacles which mean that there might be still some room for flexing.
I kind of like the idea but still I probably would not be one who would do it. It reminds me of a BJ without the safety parts that control the BJ itself "pull out" but which still doesn't have the "wrong way" press in of the lower BJ on a bug beam
. I have seen enough broken stuff on the sand by people (usually newbies) who push the limit out of ignorance hoping for fun... not having it when things break especially when it is big time; quite often their first ownership and last trip to the dunes
I thought the bug had 6° of camber stock. Some of the rails I have driven a short distance (I get motion sick in a rail) get kind of "twitchy" with less camber.
I know you guys on the bottom of the earth
have pretty strict rules just like some of the European countries do. Here in the states there is the DOT (Dep't of Transportation) that has rules mostly on new cars but each state has the right to do certain things also. Some states don't seem to care while others, while not as strict as you guys are, still are stricter than some of the other states mostly for safety reasons and stolen parts.
