So, I had a looooong weekend and was time to get more done. The goal was to get the hubs off the transaxle and to coat the pan in Bedliner. I did get both done thankfully. However I think I may have broke my foot. I had the wheel hubs up on a block. While I was working on them my foot ended up underneath the axle tube. Yea well, you can guess what happened. The damn Hub/Drum rolled off the block. With the hub weight, along with the redux box... My foot is a nice black and blue now. Hard to put my boots/shoes on.
Uhg.
I had to create 2 of my own tools. As with everything it's a trial and error process. It was mostly a succsess. The Passenger side castle nut just would NOT budge. Even with the tool I made. I broke 2 11mm sockets on the torque drive. Then got a heavy duty impact gun socket. That managed to finally destroy the original 36mm castle nut I welded to the 46mm Socket. I then cut off the destroyed on and tried a brand new 36mm castle nut welded to the 46mm socket. That was destroyed as well. A bit disapointing. It worked fine on the drivers side. I ended up drilling apart the castle nut on the passenger side to remove it. So, will need to find a new one.
The drum/hub puller I made was a resounding succsess on both side. Though again the passenger side proved to be more difficult. It was actually bending parts of the angle iron, so I had to make another brace piece to put in. Was fine after that.
I also made a small error... Should never just assume. Looking at the nosecone of the RGB TRansaxle and the nosecone of the standard transaxle they looked the same to me. Well, apparently they are not. Putting the mount on the RGB transaxle and trying to put it on the pan it doesnt fit. I'll have to pust out the angle grinder and whack off the mounting area on the torsion housing and move it up. Probably take an hour or so but was unexpected.
here are the pics...
Well, sometimes with oddball stuff you have to make your own tools. The large Castle nut here is 46MM. My Torque tool fits 36mm. Here is a standoff to hold the Torque teeth.
Torque Teeth in place.
46mm socket, with 36mm Castle nut welded to it.
Torque Gear and arm attached.
Houston, we have a problem. THe metal was soft enough it started to strip. I had to pull it back off and weld more strength into it. It finally worked.
With the Castle nut off, the hub needs to be removed. This poor thing sat outside for YEARS. No way was it coming off easilly. 3 standoff's are drilled for lugs and put on.
2 Heft Angle Iron's connect everything, welded into place.
An extra puller I've had laying around for years is hooked up to my contraption. Worked like a charm
Drivers side drum pulled off. cute huh?
36mm Castle nut taking a beating on the passenger side.
Passenger side drum removed.
Initial painting of the transaxle after the power wash.
The bottom of the pan after coating with the bedliner.
Getting ready to put bedliner on the top.
Bedliner is on!
