T4 36-1 trigger wheel
RonW
Post by RonW »
i was going to try to mount my ford edis trigger wheel on my DTM pulley but w/o special equipment to get it perfectly centered, i decided to go another route and look for a bolt on trigger wheel. my search came up empty so i designed my own by taking measurements off of the hub. the OD is 170mm w/ 5mm deep notches
i am going to have a machine shop laser cut this out of A36 1/8" steel
i left the missing tooth on so you could decide where you want it depending on the VR mounting location.
before i place an order for myself, i am feeling out the interest from others and if great enough, do a larger order.
912R + STi 2.0 Turbo JDM v8
Redline Weber
Type IV Target
Post by Redline Weber »
I manufacture this (similar) target, Type IV, for FAT.
I do not know the diameter you require ?
Also there is sensor bracket that mounts to the oil pump.
This setup is used by Wide Open Baja Tours.
I have the ability to make a "target" to the size you require,
remember I was in the small group that invented this system.
I need to make about 100 parts, to keep costs low.
Give it to us !
RonW
Post by RonW »
well, today i looked at my Ford EDIS VR to determine a mount to use w/ a trigger wheel behind the pulley and the choices are slim w/ my full flow cover on the bottom and oil lines on the d-side. that left me w/ p-side mounting. the mount adjusts up/down in/out a few mm to get it positioned perfectly at 90* later.
slowtwitch
Post by slowtwitch »
Ron, Looks Good!!!
pete
RonW
Post by RonW »
finally getting a chance to work on the car again but just thought i'd post up some pics as i near a bolt on solution to my problem. hopefully finish up w/ wiring this weekend.
MarioVelotta
Post by MarioVelotta »
H.O.T.!! Wanna give up the shop that did the machining? : Thumbs Up:
[email protected]
RonW
Post by RonW »
i ordered 20 of them cuz there wasnt much difference in price than just ordering 1! i figured this would be something kinda kewl for the T4 community if they wanted one + help me get my investment back so pm since im not an official vendor but i think $40 shipped seems fair. i'll get mine running first to make sure all is good before i send any out :oops:
the machine shop i went thru was emachineshop.com the system works pretty kewl actually. you d/l their design software, watch there basic tutorial video make your design, assigning the matieral, the machine to make the cut/milling, the finishing then press "price" and a window will pop up telling you the cost and time and which in my case turned out to be exactly what the algorithm predicted and date it arrived! the cost was very reasonable.
MarioVelotta
Ow sure, I drew up my exhaust flanges on there to get a price. It wasn't very reasonable. Maybe because it was 3/8"? Those are nice though, good luck!
P.S. Too bad I don't have a type 4 :cry:
[email protected]
fl_buggy
Post by fl_buggy »
RonW, is there anyway you can determine if this wheel will fit behind a stock fan? I'd really like to buy one of your wheels, but I'm running the stock pancake cooling.
I'll pull the shroud off this week and take a look at the fan arrangement, but if you know off hand, that would be great.
RonW
Post by RonW »
since i a not running it, i cant say for sure but based on what Rick_Eberle did i is possible but you'd likely have to take and 1/8" off of the mounting surface of the fan. but pm me since again, i am not a vendor and dont want to put off the moderators.
RonW
Post by RonW »
not that i should be surprised but wow it actually worked! at first, cranking it over, i got nothing :( started to test for power and then i realized if forgot to wire power to the coil :oops: fixed that in a few min and cranked it over and got backfires thru each throttle body one at a time w/ the compression stroke so its just a matter of playing w/ the timing offset when i have time tomorrow
QUESTION:
1)since my vr is at 3 oclock which is 90* in front of TDC, i need to have my missing tooth 90* in from of that so at BDC, is that correct?
2)i have set my wires for 1 & 3 for coil tower A (Left hand bank as you look at the plug) and 2 & 4 on coil tower B. correct?
fj_buggy:
still havent had the chance to put one of the wheels behind a 914 fan and housing but i'll try soon.
bj
Post by bj »
missing tooth 90* after the VR sensor sounds about right to me:
http://www.autosportlabs.net/MJLJ_V3_ve ... stallation
you can also find the wiring on this site as well. can't recall what i've read.
bj
RonW
Post by RonW »
well, it kept back firing as though it were 180* off so i switch the plug wires between the coil packs and it started right up!
http://www.youtube.com/watch?v=zdZTyzAWHlM&feature=user
http://www.youtube.com/watch?v=XR29dHmqDcE&feature=user
bj
Post by bj »
sweet.
you have any more of those wheels?
bj
RonW
Post by RonW »
pm sent.
