'73 Bug. Will 185 65 15 or 195 65 15 Tires fit on it?
Jim Ed
Post by Jim Ed »
The 5.5 rims have 4-1/2 inch back spacing.
https://www2.cip1.com/ProductDetails.as ... -601-025-G
Re: '73 Bug. Will 185 65 15 or 195 65 15 Tires fit on it?
Post by Marc »
Yes. 5½" is the minimum acceptable rim width for a 195, but it'll do.
http://www.yokohamatire.com/tires_101/c ... eel_width/
Jim Ed
Post by Jim Ed »
Marc wrote:Yes. 5½" is the minimum acceptable rim width for a 195, but it'll do.
But, will the 195's fit on the Beetle?
Post by Marc »
Yes. With 4½" backspace you may find that the front inner sidewalls contact the lower control arms at full steering lock; simple enough to adjust the steering box stops in a bit if that's an issue. Shouldn't be any fender clearance problem front or rear.
Jim Ed
Post by Jim Ed »
Marc wrote:Yes. With 4½" backspace you may find that the front inner sidewalls contact the lower control arms at full steering lock; simple enough to adjust the steering box stops in a bit if that's an issue. Shouldn't be any fender clearance problem front or rear.
Thanks!
