A Break Down Of the Front Suspension Parts
"Not Shown"-- #129015HB...4-bolts that bolt Front End to pan. 12mm x 90mm x 1.5mm bolts
"Not Shown"-- #AVIS Adjusters for Aluminum front ends KP
1-- #111 405 691...Grease Dust cap... Right KP...(2.065"OD without speedo drive hole)...54-7/65
1-- #111 405 692........"..........."......".......Left side KP...(2.065"OD w/speedo. drive hole)
1-- #111 405 691B...Spindle Cap Left Side...BJ..66-on...1.900"ID w/speedometer drive Hole
1-- #111 405 692B...Spindle Grease & Dust Cap...BJ..66-on...1.900"ID Right Side
2-- #111 405 671...Spindle Nut...Right hand threads...54-7/65...requires (2) "How to"
2a-- #111 405 672.........".........".....Left hand threads...54-7/65...requires (2) 2b-- #V405 015...Spindle Race Nuts...Set of 2...replaces #3 & #4...54-7/65
3-- #111 405 681...Lock plate...54-7/65
4-- #111 405 671...Spindle Nut...Right hand threads...54-7/65...requires (2)...
4a-- #111 405 672.........".........".....Left hand threads...54-7/65...requires (2) 4b-- #V405 015...Spindle Race Nuts...Set of 2...replaces #2 & #3...54-7/65
5-- #111 405 661...Spindle nut thrust washer...54-7/65
6-- #111 405 645A...Outer Ball Bearing...46-7/65 Note: inner & Outer must be the same type... No Longer Stocked Sub #111 405 647
6-- #111 405 625A...Ball Bearing Inner...46-7/65...ID=.985"xOD=2.440"x.750"No Longer Stocked Sub #111 405 627
6-- #111 405 627...Roller Bearing Inner...46-7/65...Replacement for 111 405 625A above
6-- #111 405 647...Roller Bearing Outer...46-7/65...Replacement for 111 405 645A above
6-- #311 405 625...Roller Bearing Inner...8/65-6/68
6-- #311 405 645...Roller Bearing Outer...8/65-12/77
6-- #311 405 625D...Roller Bearing Inner...6/68-12/77
6-- #211 405 625...Roller Bearing Inner T-2 65-79
6-- #211 405 645D...Roller Bearing Outer T-2 64-80
7-- #113 405 615A...Brake Drum (5 Hole)...1/54-7/65
7-- #131 405 615A...Brake Drum (5 Hole)...8/65-7/67
7a- #111 601 139... Lug Bolts 12mm stock 5-Lug
7a- #VM009566... Lug Bolts 12mm Chrome "Set of 5"
7a- #VM009565... Lug Bolts 12mm Long "Set of 5"
7a- #211 601 139... Lug Bolts 14mm stock 4-Lug
7a- #VM00 9568.... Chrome Lug Bolts 14mm 4-Lug set of (4)
8-- #111 405 625A...Inner Ball Bearing ...46-7/65...ID=.985"xOD=2.440"x.750"
8-- #111 405 645A...Ball Bearing Outer...46-7/65... 552mm
8-- #111 405 627...Roller Bearing Inner...46-7/65...Replacement for 111 405 625A above
8-- #111 405 647...Roller Bearing Outer...46-7/65...Replacement for 111 405 645A above
8-- #311 405 625...Roller Bearing Inner...8/65-6/68
8-- #311 405 645...Roller Bearing Outer...8/65-12/77
8-- #311 405 625D...Roller Bearing Inner...6/68-12/77
8-- #211 405 625...Roller Bearing Inner T-2 65-79
8-- #211 405 645D...Roller Bearing Outer T-2 64-80........Never Mix Ball and Roller Bearings on one Spindle...Both Ball or Both Roller....
9-- #111 405 641A...Seal KP 1/49-7/65...40x62x11.5mm
9-- #131 405 641A...Seal BJ Drum 8/65-1/68...38x52/56x7.5/9mm
9-- #111 405 641B...Seal BJ Drum 1/68-8/79
9-- #311 405 641A...Seal BJ Disc 8/66-5/68
9-- #311 405 641B...Seal BJ Disc 6/68-7/77
9-- #211 405 641D...Seal T-2 8/63-79
10-- #V405017...Inner Spacer that Seal rides on. .585" thick x 1.575" OD. x .985" ID.
11-- #111 405 301...Spindle Left Side...59-65
11-- #113 405 301...Spindle Left Side...To fit late Brake Drums (4 or 5 hole)...8/65-
11-- #111 405 302...Spindle Right Side
11-- #113 405 302...Spindle Right Side...To fit late Brake Drums (4 or 5 hole)...8/65-
11-- #111 405 301D...Spindle Right Side...Disc Brake Type _up to 7/65
11-- #111 405 302D...Spindle Right Side...Disc Brake Type _up to 7/6511-- #V430 003...Front Spindle Beef-up Kit
.... Beefed-up K.P. Spindle with kit installed
12-- #..........................Small Pin that holds spacer in Place...
12a-- #VKPS.. Steel Spacer...(hard to find)
13-- #111 498 021...King Pin Rebuild Kit (for both sides)...1/54-7/65...(2 lbs) ....Requires Special Reamer to install...
Note: When replacing the KP's, the LP's # 14 will normally need replacing.
13-- #211 498 041A...Link Pin Set...T-2 Bus 8/63-7/67 (1 set required per vehicle)
13a- Set up Link Pin Shims for T-2 (Outside Link) *info
14-- #111 498 051...Link Pin Kit...adj. with shims...2-sides...1/54-7/65...(3 lbs)
14-- #211 498 041A...Link Pin Set...(1 set required per vehicle) T2 64-67
14-- #211 405 356...T2 64-67 King Pin w/lower Link Pin Bushings L or R
14-- #211 405 317B...T2 62-67 King Pin Bushings Lower 62-67
14a-- #___ ___ ___ ...Pinch Bolt to Adjust Link Pins Note these should be retightened after some running time.
15-- #111 405 351...Link...Left Side
15-- #111 405 352...Link...Right Side
15-- #V430003...Beef-up Kit for off-road Buggy's & Baja's
Note: these must be Welded in Before King & Links are rebuilt.
16-- #N18 515 1...Grease Zerk fittings...6mm Straight
16-- #N18 523 1...Grease Zerk 6mm...45 degree
16-- #N18 516 1...Grease Zerk 8mm... used on some King Pin ft beams...
17-- #111 405 105D...Torsion Arm...Top...
17a- #1045150HB...Link Pin Pinch Bolt** Must retighten at least once after rough terrain use.**
18-- #111 405 151C...Torsion Arm...Lower...
18a- #1045150HB...Link Pin Pinch Bolt** Must retighten at least once after rough terrain use. **
19a-- #111 411 151...Torsion Bar Screw
19-- #111 411 151...Torsion Bar Screw Lock Nut
19b-- #M165138....Link Pin Urethane Kit 4-Seal
20-- #111 413 403A...Top Shock Bolt. Early type had step w/taper lock. Not available
20-- #127015HB... Top Shock Bolt (some new Beams) 12-1.50-70mm
20-- #111 413 403A...Top Shock Bolt.. Straight ... 12-1.75-65mm
. . . Note early type can be drilled out and taped for Later type Bolt. . . .
21-- #113 413 031B...Shock Absorber to Ch. 115 999 000.
21-- #KG4521...KYB HD Shock
21-- #V513 001...Coil Over Shock...adjustable. .Lower Shock Mount for Long Travel Front End
Note: Most aftermarket early KP front shocks will also fit the rear 1950 to 1977, stock rear IRS shock has wider mounting sleeve to center shock in mount.
22-- #111 401 273...Rubber Stop...Stock
22-- #V413 103...After Market HD Stop (Sold in Pr's)
23-- #V1015N...10x1.5...Nut for lower Shock...or V1015NL...Locking Nut
24-- #111 411 027...K.P. Torsion Bars Set Top or Bottom"Note: K.P. Bars are no longer being produced."
24-- #V114 155...K.P. Torsion Bar Leaf , Wide Leaf .725" x .120"
24a- #V11 411 500...K.P. Torsion 1/2 Leaf Top or Bottom.360 x .120"
KP uses (4) full with bars & (4) 1/2 width bars, 2 on each side to make a square stack. Top & Bottom are the same.
25-- #111 401 315...Fiber/Bakelite Bushing... 1.771"/45mm O.D. x 1.456"/37mm I.D. T1 49-64 & Ghia 56-64
25-- #VM16 5139...One piece aftermarket Bushings for Ft ends w/ Micarta Bushings
25-- #V11 401 301...Needle Bearing...Outer KP ... 1.815"/46mm O.D. x 1.455" I.D."
25-- #V413 109...Outer (4) bushings Replacement for Stock Fiber Bushings... 1.771"/45mm O.D. x 1.455" I.D.
25-- #VM16 5137...Outer Replacement (4) replaces stock outer Fiber Bushings... 1.770"/45mm O.D. x 1.455" I.D
25-- #V104 246...Outer Replacement for Stock Needle Bearings... 1.815"/46mm O.D. x 1.455" I.D.
25-- #V413 108... Inner & Outer one piece Bushings for Aluminum Front ends (4-pcs)
25-- #VM16 5143...One piece aftermarket Bushings for Alum Ft ends w/45mm tubes
26-- #111 411 027...Torsion Bars Set Top or Bottom...Same as #24
26a- #V11 411 500...K.P. Torsion 1/2 Leaf Top or Bottom .360 x .120"
27-- #111 400 401A...Rebuilt KP Front End ( Spindle to Spindle ) Approximately 80 lbs "pick up at shop"
27-- #111 401 021A...Axle Beam NEW...Bare with all 8 new bearings installed Approximately 28 lbs 40" long & 40" girth "can be shipped USPS"
27-- #V401 001...Aluminum Front End w/Shock Towers
27-- #V401 000...Aluminum Front End (No Shock Towers)
27-- #V10 4160...Long Travel Shock Mount Kit for K.P. front end
27a- #VM22 2815...Caster Shim Kit
27b- #VM22 2802...Torsion Adjusters
28-- #N18 515 1...Grease Zerk 6mm Fitting (4) per car
28-- #N18 516 1...Grease Zerk 8mm...used on some K.P. Beams
28-- #N 018 516 1-2 Grease Nipple 8 x 1 mm
28-- #N 018 530 1-2 Grease Nipple 10 x 1 mm
29-- #111 401 315...Fiber/Bakelite Bushing...See #25...
29-- #VM16 5139...One piece aftermarket Bushings for Ft ends w/ Micarta Bushings
30-- #113 405 615A...Brake Drum (5 Hole)...1/54-7/65
30-- #131 405 615A...Brake Drum (5 Hole)...8/65-7/67
30-- #111 405 615B...Brake Drum (4 Hole)... 8/67-12/77
30a- #211 601 139... Lug Bolts 14mm stock 4-Lug
30a- #VM00 9568..... Chrome Lug Bolts set of (4)
30a- #111 601 139... Lug Bolts 12mm stock 5-Lug
30a- #VM009565... Lug Bolts 12mm Long "Set of 5"
31-- #131 405 641A...Oil Seal Fr. BJ - 5-Lug Drum 8/65-1/68 Ch. 116 000 001 to 118 857 239...38x52/56x7.5/9mm
31-- #111 405 641B...Oil Seal Fr. BJ - 4-Lug Drum 1/68-8/79 Ch. 118 857 240
32-- #113 405 311E...Left Spindle...Shoe Brake
32-- #113 405 312E...Right Spindle. Shoe Brake
32a-- #V40 5020...Weld on Spindle for B.J. Wheels & Bearings (Great for making Trailer Axels)
. . . Spindle diameter for Inner bearing is 1.0618"/1.0622" (26.97mm/26.98mm) . . .
. . . Spindle diameter for Outer bearing is 0.6870"/0.6874" (17.45mm/17.4mm) . . .
33-- #111 405 131...B.J. Upper Seal...(2) required
33-- #131 405 131...B.J. Upper Seals...Some parts books give this number
33a--#VM165145....Ball Joint Urethane Seal kit "all 4-seals"...$14.95
33b--#M165138....Link Pin Urethane Kit 4-Seal ...$14.95
34-- #131 405 129...B.J. Lower Seal...(2) Right and Left side
35-- #V11 401 301... B.J. Top Outer Bearings...46mm/1.811" O.D. x 1.475" I.D.
35-- #111 401 315... B.J. Top Inner Bushings...1.770"/45mm O.D. x 1.460" I.D.
35-- #AC413110......B.J. Urethane Bushing Kit (outer 4 only)...The outer ones are normally the only ones that go bad
Front End Bushings
36-- #V11 401 301C...B.J. Lower Outer Bearing...50mm/1.970" O.D. x 1.693"/ 43mm I.D.
36-- # 111 401 315...B.J. Inner Bushing... 1.770"/45mm O.D. x 37mm/1.460" ID.
37-- #131 411 107A...Torsion Leaf Set...B.J. .840" wide leafs
37-- #USBT...B.J. Torsion Leaf Set "Recycled".....840" x .110" thick Leafs
37-- #V31 411 840...B.J. Torsion Leaf "Wide ...840" x .110" thick Leaf
37-- #V31 411 360...B.J. Torsion Leaf "Narrow" ...360" x .110" thick Leaf
Top and bottom leafs are the same. But KP & BJ are not the same
38-- #131 411 107A...B.J. Torsion Leaf Set
38-- #USBT...B.J. Torsion Leaf Set "Recycled"
38-- #V31 411 840...B.J. Torsion Leaf "Wide ...840" x .110" thick Leaf
39-- #113 401 021D...B.J. Front Axle Beam w/Bearings
39-- #VJ10 4199...B.J. Lowered Torsion Beam
39-- #VM22 2801...B.J. Torsion Bar Adjuster
Note: B.J. beams rust from inside out.To prevent this, drill a small hole in shock tower and cover inside with oil before plugging hole.
39-- #VM22 2815...Caster Shim Kit
39a--#113 401 021RK...B.J. Beam Repair Kit (not shown) repairs the area btween the upper & lower tubes T1 66-78 & Ghia 66-74"One set does one side" welding required.
39b- #V11 706...Bolt Plates...Pan to Front end ( 1 13/16" x 1 3/16" )
39- #835125HB...Steering Stop Bolts on B.J. Beam (Not Shown)
40-- #111 411 151...Torsion Bar Grub Screw...49-79 T1,2,3 & Thing
41-- #111 411 151...Torsion Bar Grub Screw Lock Nut
42-- #131 498 441...Shock Extension Bolt Kit...Required on Early stock Shock
43-- #113 413 031E...Shock Absorber Fr CH. 116 000 001...8/65-12/77
43-- #113 413 031EU...Shock w/built in #42 w/rubbers & washers Does not require Bolt Kit
43-- #V413 001...........Coil Over Adjustable Shock
43-- #V413 006...........Ft Shock for Lowered Ft. Ends
44-- #............................Shock Nut Lower BJ...
44-- #............................Shock Self Locking Nut...Nylock...
45-- #131 405 361F...Ball Joint Upper
45-- #211 405 371A...Ball Joint Upper or Lower...T-2 Bus 68-7/79
46-- #131 405 319...Camber Adjuster...Mark location before removing
47-- #411 513 481...Nut-12mm Self-Locking...Ball Joint...
48-- #411 513 481... Nut-12mm...Same as #47
49-- #113 405 311E...Spindle Left Side...8/65-78
49-- #113 405 312E...Spindle Right Side...8/65-78
50-- #131 405 151A...Torsion Arm Lower Left...8/65-12/77
50-- #131 405 152A...Torsion Arm Lower Right...8/65-12/77
51-- #131 405 103A...Torsion Arm Upper Left...8/65-12/77
51-- #131 405 104A...Torsion Arm Upper Right...8/65-12/77
52-- #111 411 151...Torsion Bar Screw
52a-- #111 411 151...Torsion Bar Screw Lock Nut
53-- #N18 515 1...Grease Zerk fittings...6mm Straight...Most BJ ft ends
54-- #131 405 371G...Boll Joint Lower...66-on...
54-- #211 405 371A...Ball Joint Upper or Lower...T-2 Bus 68-7/79
55-- #131 411 309...Stabilizer Bar, Front 66-79 Std.
56-- #111 498 101A...Stabilizer Mounting Kit..Fr. Ch. 116 000 001
57-- #113 609 139...Ft. KP Backing Plate...52-58...
57-- #113 609 139A...Ft. KP Backing Plate...57-64...
57-- #V609 139.........Backing Plate Left... BJ Shoe Brakes...
57-- #.............................Backing Plate Left...BJ Disc Brakes...
57-- #.............................Backing Plate Right...BJ Disc Brakes...
58-- #.............................Backing Plate Bolt...
59-- #311 405 641A...Seal Disc Brake...8/66-5/68...1.400"x2.060"x.250"
59-- #311 405 641B..Seal Disc Ch.118857240->6/68-7/77.1.5"x2.055"x.340"
59-- #111 405 641A... Seal KP 1/49-7/65...40x62x11.5mm
59-- #131 405 641A...Seal BJ - 5-Lug Drum 8/65-1/68...38x52/56x7.5/9mm
59-- #111 405 641B...Seal BJ - 4-Lug Drum 1/68-8/79
59-- #211 405 641D...Seal T-2 8/63-79...50x65x8mm
60-- #311 405 625...BJ - Inner Bearing 5-Lug - Brk Drum Taper Roller ...8/65-6/68...
60-- #311 405 625D...BJ - Inner Bearing 4-Lug - Brk Drum Taper Roller...6/68-12/77
60-- #111 405 625A...Ball Bearing Inner KP...46-7/65...ID=.985"xOD=2.440"x.750"
60-- #111 405 645A...Ball Bearing Outer KP...46-7/65... 552mm
60-- #111 405 627...Roller Bearing KP Inner ...46-7/65...Replacement for 111 405 625A above
60-- #111 405 647...Roller Bearing KP Outer...46-7/65...Replacement for 111 405 645A above
60-- #311 405 645...Roller BJ - Outer Bearing 4 & 5-Lug ...8/65-12/77...ID=.687" OD=.1.570"
60-- #211 405 625...Roller Bearing Inner T-2 65-79
60-- #211 405 645D...Roller Bearing Outer T-2 64-80
61-- #311 405 583A...Brake Rotor BJ ...T-1 66-77, T-3 66-71 & Ghia 67-74
61a- #211 601 139... Lug Bolts 14mm stock 4-Lug
61a- #VM00 9568..... Chrome Lug Bolts 14mm 4-Lug set of (4)
62-- #311 405 645.. BJ - Outer Bearing 4 & 5-Lug - Drum Taper Roller ...8/65-12/77....689"IDx1.571"ODx.580"
63-- #311 405 661...Thrust washer...8/65-12/77
64-- #131 405 669...Locking Nut...Left side
64-- #V31 405 669...Locking Nut...Left side
64-- #131 405 670...Locking Nut...Right Side
64-- #V31 405 670...Locking Nut...Left side
65-- #111 405 691B...Spindle Cap Left Side...BJ 66-on...1.900"ID w/speedometer drive Hole
65-- #111 405 692B...Spindle Grease & Dust Cap..BJ 66-on...1.900"ID Right Side
65-- #111 405 691...Grease Dust cap... Right KP...(2.065"OD without speedo drive hole)...54-7/65
65-- #111 405 692...Grease Dust cap....Left side KP...(2.065"OD w/speedo. drive hole)
66-- #V412 006...Stock Super Beetle Springs...Set of 2
66-- #V412 005...Hi-Perf Super Beetle Springs...Set of 2
66-- #V412 004...Lowered Strut Springs...Set of 2...
67a-- #113 412 303... SB Strut Stop ...up to 7/73
67a-- #113 412 303A...Strut Upper Stop...SB up to 73
67a-- #133 412 303A...Strut Upper Stop...SB 74-On
67-- #V266 102A...Strut Assembly...recycled 3-bolt 8/70-73
67-- #V266 103A...Strut Assembly...recycled press in 73-79
Complete Recycled Strut Assy. with Strut tube, insert spring. Snubbers and bearing cap completely assembled.
These are Guaranteed straight with good springs. Sorry we cannot guarantee the strut insert or strut bearing in them, they are most likely good.
67-- #V412 000...Lowered Strut Super Beetle 71-73...pr...
67-- #V412 001...Lowered Strut Super Beetle 74-79...pr...
67-- #113 412 031D...Strut Insert Fr. Ch 133 3003 656...8/70-7/73...3-Bolt
67-- #133 412 031B...Strut Insert Fr.Ch 133 3003 656...8/73-8/79...Clamp
67-- #V412 002...Lowered Strut Insert Super Beetle 71-73...pr..
67-- #V412 003...Lowered Strut Insert Super Beetle 74-79
68-- #113 407 361E...Ball Joint Super Beetle...8/70-7/73...3-Bolt
68-- #133 407 361...Ball Joint Super Beetle..8/73-8/79...Clamp
69-- #VTARM...Track Arm Forged Steel...8/70-7/73
69-- #VTR74...Track Arm Stamped Steel Welded...8/73-8/79
70-- #..........................Self Locking Nut
71-- #113 407 311E...Spindle...Left...3-Bolt...8/70-7/73
71-- #113 407 312E..Spindle...Right... 3-Bolt...8/70-7/73
Spindle diameter for Inner bearing is 1.1409"/1.1417" (28.98mm/29.00mm) . . .
71-- #VLSBSK...Spindle...Left...8/73-8/79
71-- #VRSBSK...Spindle...Right...Clamp Type...8/73-8/79
71a- Super Beetle suspension
72-- #...........................Backing Plate Left Side...
72-- #...........................Backing Plate Right Side...
73-- #...........................Backing Plate Bolt...
74-- #311 405 641A...Oil Seal (For Disc. Brakes)...8/66-5/68...1.400"IDx2.060"ODx.250"
74-- #311 405 641B...Seal Disc. Brakes Fr. Ch 118 857 240...6/68-7/77 See #9 & #59 for KP & BJ front ends seals.
75-- #311 405 625D... Inner Taper Roller Bearing Ch 118 857 240...6/68-12/77
75-- #311 405 645...Taper Roller Bearing Outer...8/65-12/77
75-- #111 405 625A...Ball Bearing Inner...46-7/65...ID=.985"xOD=2.440"x.750"
75-- #111 405 645A...Ball Bearing Outer...46-7/65... 552mm
75-- #111 405 627...Roller Bearing Inner...46-7/65...Replacement for 111 405 625A above
75-- #111 405 647...Roller Bearing Outer...46-7/65 Replacement for 111 405 645A above
75-- #311 405 625... Roller Bearing Inner...8/65-6/68
75-- #211 405 625...Roller Bearing Inner T-2 65-79
75-- #211 405 645D...Roller Bearing Outer T-2 64-80
76-- #113 405 615D...Brake Drum...SB 70-7/72
76-- #113 405 615H...Brake Drum...SB 89/72-on
76a- #211 601 139... Lug Bolts 14mm stock 4-Lug "
76a- #VM00 9568..... Chrome Lug Bolts 14mm 4-Lug
77-- #311 405 645...Outer Taper Roller Bearing ...8/65-12/77
78--.#311 405 661...Thrust Washer...8/65-12/77
79--.#131 405 669...Locking Nut...Left side
79--.#V31 405 669...Locking Nut...Left side
79--.#131 405 670...Locking Nut...Right Side
79--.#V31 405 670...Locking Nut...Left side
80--.#131 405 691...Dust Cap Left Side
80--.#131 405 692...Dust Cap Right Side
