Engine Bolts Dimensions
Info from http://1800vw.bizhosting.com/0.case.htm
1-- #111 199 101...Half Moon Starter Bolt Std. Tran. 10x110mm..(4.33") 13/1600cc Right Side of Car
1-- #111 199 103...Half Moon Starter Bolt Std. Tran. 10x70mm..(2.750")12/1600cc Right Side of Car
1--#N 010 494 2...Hex Head Bolt "Automatic"...BM10x125
2-- #113 101 211G...Gasket Gen/Alt Pedestal... (comes in gasket set)
3-- #8125N...Hex Nut...8mm
4-- # N 12 241 11... Spring Washer 8mm
5-- #113 101 211G...Pedestal Alt./Gen...with 105 mm Use with Gen.or Alt.
5-- #V101211...Pedestal Alt.Gen...with 105 mm Gen.or Alt... Chrome
.......Alternator Kit w/chrome pedestal order.
6-- #VN1015... ( 043 101 109B )...Case Insert... Pressed in Nut insert on left side/Late cases
Note: This is shown on wrong side of case "Used on Left side of car"
7-- #113 101 221B...Oil Deflector plate...
8-- #N 014 443 12...Stud...AM8Ax38
9-- #111 129 720...Washer...8,4
10-- # N 12 228 2... Spring Washer 8mm
11-- #8125N...Hex Nut...8mm
12-- #111 115 161...Hex Nut...8mm
13-- #...No Longer Available...
14-- #N 900 044 02...Stud...AM8Ax56
14-- #N 014 491 2...Stud...CM10A/M8x56
15-- #8125N...Hex Nut...8mm
16-- # N 12 228 2 / N122282... Spring Washer 8mm
17-- #N 014 443 12 / N 014 443 11...Stud...AM8Ax38
18-- #043 101 129... Case Washer (6) 12, 2x22x3,1
19-- #043 101 131...Case Nut 12x1.5mm (6) used on late model cases with #57 "O" ring
19-- #113 101 131A...Case Sealing Nut 12mm (6)...used on early cases without "O" ring #57
20-- #113 115 631...Guide Tube
21-- #8125N...Hex Nut 8mm
22-- # N 12 228 2... Spring Washer 8mm
23-- #N 013 830 4...Sealing Washer...A8x14
24-- #8125N...Hex Nut...8mm
25-- # N 12 228 2... Spring Washer 8mm
26-- #N 014 443 12...Stud...AM8Ax38 Oil Pump Self Sealing Nuts 6mm & 8mm
26--# ...Stud...6mm
26-- #N 14 402 1...Oil Sump Step Stud...6mm to 8mm... The striped 6mm hole is correct size to be taped for American 1/4-20 or repair case with 6mm Helicoil
27-- #113 101 122A...Plug...F19,2x8
28-- #N 014 542 1...Stud...AM6Ax21
28-- #N014 478 1...Stud...CM8A/M6x21 " Step studs 6 to 8 & 8 to 10mm ---
28a--#043 101 149...Oil Pickup assy. ...This must be tight in case...all 1600cc
29-- #113 101 157C...Cam Plug...65-69...
29-- #040 101 157...Cam Plug "New" type Plastic/Rubber
29a-- Not Shown...Cam Bearings #26 on --
30-- #N 014 660 2...Stud...AM8Ax59
30-- #N 014 408 3...Stud...CM10xM8x62
31-- #111 101 123...Dowel .197" dia x .315" long
Note: 5 main bearing Dowels are used, some cases used in very cold climates had one extra dowel hole drilled in the case. Most bearings will not use this extra dowel.
32-- #N 011 008 18Hex Nut...8mm
33-- # N 12 228 2... Spring Washer 8mm
34-- # N 12 228 2... Spring Washer 8mm
35-- #N 010 352 10...Hex Bolt...Upper..M8x55
36-- # 113 101 175...Hex Nut Self-Locking...M6
37-- # N 12 228 2... Spring Washer 8mm
38-- #043 101 149...Oil Pickup assy. ...This must be tight in case...all 1600cc
39-- #N 014 545 2...Stud...AM6Ax36
40-- #113 101 139...Step Stud...oversize...
41-- #113 115 193...Drain Plug...
41-- #VM00 5110...Drain Plug w/magnet...
. . . Prevents metal from traveling around your engine in the oil. Clean it thoroughly every time you change the oil. . . .
42-- #043 101 025...Case, Late Dual Oil Relief w/rear hanger for T2 & T3 1300/1600cc
42-- #211 101 025...Case, Late Dual Oil Relief ...T1 & T2 only 13/1600cc
42-- #043 101 025A...New Alum Case, Late Dual Oil Relief -->
42-- "New Alum Super Case for Large Motors up to 94mm bore cylinders & 86mm stroker cranks --
Seems like every body is making new VW Cases now. Every thing from stock to super cases rounded out to except 86mm Stroker cranks, shuffle pined and cut for 85.5 , 90.5/92 or 94mm cylinders with 8 or 10mm case studs or un-drilled if you want to relocate the cylinder studs.
43-- #113 101 145A...Bushing
44-- #N 014 443 12...Stud...AM8Ax38
44-- #N 014 452 1...Step Stud...CM8A/M6x23
44-- #N 014 458 1...Step Stud...CM10A/M8x35
45-- #113 101 111...Dowel Pin...8M8x17,5
46-- #N 014 396 8...Stud...AM8A50
46-- #N 014 428 9...Stud...AM8Ax48
47-- #N 014 398 7...Stud...AM8Ax27
47-- #N 014 482 1...Step Stud...CM10A/M8x27
48-- #N 014 428 9...Stud...AM8Ax48
48-- #N 014 484 5...Step Stud...CM10A/M8x48
49-- #N 014 396 8...Stud...AM8A50
49-- #N 014 428 9...Stud...AM8Ax48
50--
51--
52-- #
53-- #
54-- #
55-- #
56-- #
56-- # 113 115 349...Oil Block Off Plate.. Used on Universal cases and T-3 converted to T-1 if case Drilled for T-1 Dipstick.
57-- #113 101 125..."O" Ring Between Case Halves...10x4...Late Model Cases Only (6)
58-- #...12mm Case Stud 9 3/8" long...Lower (3)
59-- #N 014 491 2...Stud...CM10A/M8x56
59-- #...12mm Case Stud 9 3/8" long...Lower (3)
60-- #...12mm Case Stud 9 3/8" long...Lower (3)
60-- #N 014 485 2...Stud...CM10A/M8x97
61-- #113 101 112...Plug...A6,3x17
62-- #N 14 396 1...8mm Oil Pump Studs...8 x 50mm (1.969")
62-- #N 14 442 1...6mm to 8mm Oil Pump Step Stud ( 6mm stud when threads are striped in case )
63-- #113 101 118D...Plug...E14,2x8,8
64-- #
65-- # N 12 228 2... Spring Washer 8mm
66-- # N 12 228 2... Spring Washer 8mm
67-- #043 101 130...Case Savers "Stock for 8mm late model studs"...M12x1,5A/M8x29
Note: 8mm studs introduced in 8-1972 in the T-1 motor
67-- #043 101 130A...Case Savers "M12x1,5A/M8x34
68-- #N 040 262 2...Hex Bolt...M8x50 Lower
69-- #N 14 502 1...Head Stud 10 x 1.5 x 204mm(8")...Top Outer DP & SP Note: 8mm studs 1st appeared in 8-1972
69-- #VTSP...Head stud...10mm x 8"...
69-- #V8X8...Head stud...8mm x 8"...
69-- #AC93ss102...Self Tapping Stud 8" Replace Stud w/pulled threads
69-- #N 14 505 1...Head Stud 10 x 1.5 x 188mm(7.4")...Top Center DP.
69-- #N 14 506 1...Head Stud 10 x 1.5 x 240mm(9.5" to 9 3/8")...Lower DP & SP
....Note case with deep sink #3 use another 9.5" stud in the top left front. Gives extra strength by threading in main bearing saddle.
69-- #V8X9375...Head stud...8mm x 8.375"...
69-- #VLHS...Head stud...10mm x 9.5"...
69-- #V10X7250......Head Stud 10 x 1.5 x 178mm(7")...Top 40hp
69-- #V10X750.......Head Stud 10 x 1.5 x 7.5" 36 hp Studs...
69-- #V10X85.......Head Stud 10 x 1.5 x 8" long...
69-- #V10X9375..Head Stud 10 x 1.5 x 228mm(9")...Lower 40hp can use 9 3/8"
69-- #VC1279........Head Stud Set 10mm DP Chrome Moly....10mm x 1.5mm
69--#043 198 035DP...Head Stud Set 8mm D.P.... 8 x 1.25mm
Not Pictured
69a-- #043 101 457...Head Nut for all 8 x 1.25mm Studs..."
69a-- #021 101 457...Head Nut for all 10 x 1.5mm Studs...
Not Pictured
69a-- #043 101 465...Washer for all 8mm head Studs...
69a-- #111 101 465...Washer for all 10mm Head Studs 10 x 1.5mm...
70-- #N 010 496 2...Hex Bolt...M10x120...Automatic
71-- #N 14 411 4...Case to Trans Stud...10 x 1.5 x 85mm/3.25" long (2) required
72-- #N 011 010 11...Hex Nut...M10
73-- #N 012 230 7...Spring Washer...B10x21x1
74-- ...Case must be Purchased as Set of Right & left side...
75-- ##V107015B...Case to Tran. Bolt. "Left Side".10 x 70 x 1.5 mm...when Nut is used
75-- #VN1015... Case Insert Nut. "Left Side". Pressed in Nut insert on Late case $2.65
75-- #111 199 101...Half Moon Starter Bolt Std. Tran. 10x110mm..(4.33") 13/1600cc
75-- #111 199 103...Half Moon Starter Bolt Std. Tran. 10x70mm..(2.750")12/1600cc
Lifter bores new are .7480" to .7488" diameter and maximum wear limit is .7500" ...The stock radial play is .0008"/.0024" and the wear limit is given as .0047" ....You can have the lifter bores sleeved but this would be a little expensive on a stock case.
** Stroker Rods normally available in lengths of 5.394 , 5.500" , 5.600" , 5.700" , with VW and Chev Journal diameter being used the most often.
.......Compare P&C sizes, 77mm 40hp to 94mm Big Bores
Turbinepowered
Re: Engine Bolts Dimensions
Post by Turbinepowered »
What is # 13 in the pic? Almost looks like an alternative alternator stand?
sideshow
Post by sideshow »
Turbinepowered wrote:What is # 13 in the pic? Almost looks like an alternative alternator stand?
Its an alternator stand, US spec FI model.
Turbinepowered
That's what I thought. It looked an awful lot like the alternator stand (FI) that's sitting in a box in my garage, awaiting the chance to be repurposed to a use in a CIS powered Beetle. :D
Stray Catalyst
Post by Stray Catalyst »
I've managed to lose one nut from the heads of a 1600DP, 1974. My 1969 type 1 motor uses larger ones - and I'm having some difficulty following the diagram for these, as several nuts appear to be in the right part of the diagram. Any idea which sizes are most likely?
Stray
