I pulled my heads of my 2.0 liter to use on a bigger engine build and put some fly cut standard bus heads back on.
Now original this engine pulled 130 HP with modified 42/36 bus heads. Type 1 pistons, H beam rods and 316 Schleicher cam.
But the Schleicher cam is a bit to big for the 39/33 bus heads, with 9.7 comp.
What do you guys have for recommendation for a cam that will pull strong with this combo.
So:
71x94 Type 1 22mm pin pistons
H-beam Rods
39/33mm valved heads a bit polished on inlet channel
Fly cut 1mm (chamber 47mm) comp ratio 9.7.
40mm twin webers
Thanks in advance
Eddie
What cam for 2.0 with small valves
- dstar5000
Re: What cam for 2.0 with small valves
CB 2022....
DON
DON
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
