Hello everybody merry Christmas ,
Building my type 4 engine and tried to degree my cam (86b) it seems do be way too advanced . Here are some pics for you to check , even by eye you can see that it’s too advanced . Using type 1 lifters .
Cam shaft impossible to time
Re: Cam shaft impossible to time
Here
- sideshow
To me it looks like the gear is mis-clocked. Beetles normally the oil pump drive slot to be pointing at the timing mark (3 bolts)
Have you verified that TDC is right .
Please remove those internal tooth lockwashers. Use waves or just Loctite.
- dstar5000
VERIFY TDC AND THEN TAKE YOUR CAM CARD AND GO BY THAT...
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
