2.8 Rebuild / TwinPlug conversion
- Bills914-4
My new rebuild I just finished,(still putting together megasquirt2xtra ignition/8 plugs)
84c x 103 ( 2800cc )
5.7 h-beam rods/ new 3/8 arp2000 bolts
moly coated main,rod & cam bearings
new pauter dual pattern cam ( 1" base circle ) .560 lift, 320 dur./274@ .050
1.48 pauter bushed roller tip rockers
dual taper cromoly pushrods
old school aria's forged pistons (samba classifieds) , ceramic coated tops & moly coated skirts
48x38 heads with 11 to 1 cr. & ceramic coated chambers & valve faces/plus exaust ports
CB's vw650 springs with BP's titanium retainers & modified comp-cams lash caps (geometry correction)
twin spark plug conversion ( EuropeanMotorWorks )
ceramic coated exaustports & stubb pipes
line bored & shuffle pinned (EMW )
1/2" thru bolts
1 7/8 cfr tangerine exaust / recoated black ceramic
CB's 48mm dual throttle bodies & efi system (eventually megasquirt2xtra efi )
custom dry-sump oil system
11 lbs. flywheel, KEP stage II p.p. & custom clutchnet disc
cheers Bill D.
1/2" thru bolts
cheers Bill D.
Bill DeWitt
2800cc 914-4
TwinPlugs & MegaSquirted
Now Boosted 7-10 psi
Weekend Therapy
2800cc 914-4
Weekend Therapy
- craigvwdude
- falcor
Re: 2.8 Rebuild / TwinPlug conversion
Too..much....engine....porn...
What kind of crank? It makes my welded DMS look like dumpster food!
Steve
My Baja Build
My Baja Build
- Bills914-4
, scat billet, I bought from Jorge at EMW in 2005 ?, it still std.-std. , this rebuild is gen. III , here'sSteve Arndt wrote:What kind of crank? It makes my welded DMS look like dumpster food!
more pic's, I have more ,there just not in very good order , enjoy Bill D.
Bill DeWitt
2800cc 914-4
Weekend Therapy
2800cc 914-4
Weekend Therapy
- Bills914-4
here's some more pic's , cheers Bill D.
I had to grind about 1/16 (.060 ) off oil pump shaft , it bottomed in the cam slot , I had EMW make barrel spacers oversize (.570) I then finished them .542- .545 we have a laser engraver at work ,
Bill DeWitt
2800cc 914-4
Weekend Therapy
2800cc 914-4
Weekend Therapy
Nice build! Who did your head work? What size valves are you running? Doh! See pretty picture, type too fast, read too slow. I like the cylinder/head step notch. What are the dimensions of the notch? I am interested in what head you started with.
Bill wrote:
"twin spark plug conversion ( EuropeanMotorWorks )
ceramic coated exhaustports & stubb pipes
Very nice. Interesting.
Do you perhaps have a picture of other side of heads... showing the plug positions/angles.
What deck height do you plan to be running?
Insulating/ceramic coating the exhaust port is a good idea.
An engine designer once claimed that up to half of the heat that enters the cooling system does so via the exhaust port. He mentioned high exh gas speed and resulting turbulence in that area to be the cause. This was probably referring to a watercooled application, but we get the idea...
- Bills914-4
thank you, the heads are some vintage RAT/HAM heads I picked up off ebay couple years ago , theirpinkham wrote:Nice build! Who did your head work? What size valves are you running? Doh! See pretty picture, type too fast, read too slow. I like the cylinder/head step notch. What are the dimensions of the notch? I am interested in what head you started with.
1.8 AMC castings , I kinda reconditioned them ,I had Len at HAM recut the seats on his serdi machine ,
I replaced the exaust valves, I also bac-cut them, I measured and shimmed the springs, ect.ect., The
rocker arm geometry was off, I found some deep pocket lash-caps & added .060 shim inside to extend
the valves out farther,it was easier then trying to mill the rocker pads down , here's an old sketch ,
sorry I don't remember the diameters OTOH (in my notebook somwhere) , I do remember I used
a 1/8 mill on the outside .060 deep pocket if that helps , cheers Bill D.
Bill DeWitt
2800cc 914-4
Weekend Therapy
2800cc 914-4
Weekend Therapy
- Bills914-4
Thank you, the deck is .032 machined in the head (sketch in above post), here's a few pic's , hope this helps , cheers Bill D.dawie wrote:Bill wrote:
Bill DeWitt
2800cc 914-4
Weekend Therapy
2800cc 914-4
Weekend Therapy
Inspirational. It looks like the bottom spark plugs will be accessible with the pushrod tubes and exhaust in place. This was a concern of mine.
S
S
Steve
My Baja Build
My Baja Build
- Bills914-4
[quote="Steve Arndt"]Inspirational. It looks like the bottom spark plugs will be accessible with the pushrod tubes and exhaust in place. This was a concern of mine.
S[/quote ]
hey Steve, I thought the same thing, until I got it all assembled , #2 & #3 I'm gonna have to pull the
pushrod tube halfway out to change plugs , but hey I only changed plugs about once a year in the past,
I'm thinking that maybe I can make a custom plug socket , but I haven't got to that point yet (made time)
it's lower on the list , cheers Bill D.
S[/quote ]
Bill DeWitt
2800cc 914-4
Weekend Therapy
2800cc 914-4
Weekend Therapy
- Clatter
WhOOO! That's something right there.
Thanks for sharing.
Couple o' questions...
What's the drilled/billet bracket thingie bolted to the front of the case?
download/file.php?id=14280
Why did the crank get chucked up in a lathe?
Man, it's sweet to see a motor done 'all the way' like that.
Makes me feel less crazy!
Thanks for sharing.
- Bills914-4
Hello Clatter, the crank in the lathe is for polishing purposes (budget build) I tried to do as much of the work
myself or with a little help from co-workers , the billet plate bracket is something I designed years ago
for the compressor for AC system (to get the wife to ride in the car , it helped) , here a couple of
old pic's, thank you cheers Bill D.
Bill DeWitt
2800cc 914-4
Weekend Therapy
2800cc 914-4
Weekend Therapy
- Bills914-4
Here's some more pic's , cheers Bill D.
Bill DeWitt
2800cc 914-4
Weekend Therapy
2800cc 914-4
Weekend Therapy
