cranks?
51MAN
cranks?
Prob a silly question.. couldnt find an answer..
stroke the stock 2.1 crank?
or can a type 4 stroker fit? I seem to remember the bearings are no where near the right size..
so if the stock crank.. weld and grind? or use smaller big ends? (Chevy etc)
Approx cost?
Approx cost?
wbx
Re: cranks?
DPR welded up my wbx crank and added counterweights for $350. 82mm is about the max you want to go with VW journals.51MAN wrote:Prob a silly question.. couldnt find an answer..
Approx cost?
-Damon
David Pickles
Mmmm
Sounds good a stroker crank in a wasserboxer
GoWesty in the USA do stroker engines and Pistons
http://www.gowesty.com/new_engine.htm
I don't know if the sell the parts seperate.
BAS in germany used to sell stroker cranks. don,t know if they still do.
If I find someone who will offset grind my crank I will let you know.
51MAN
150 might be a bit ambitious if you want to retain the reliability.. + more grunt is what the bus needs..
82mm stroke returns 2275cc (all things being equal) should result in more grunt, combined with a different cam (I have to retain the "DG" carb setup, so will use a webcam 218/19 IIRC, more intake to get a better mix in..)
Its either that or twin 40's and a hairy cam with port work!!
mail me..
Vielzidub 3
- sideshow
Some random picture of cranks, the stock wbx crank is “kind of” counter weighted. It has funny “pooches” compared to a bug crank.
From http://www.gearheads.dk/oxyboxer.htm
Letting DPR take a welder to one results in a more counter weighted bug style looking crank.
note how you can still see the pooches between 1-2 & 3-4 rod journals.
I wouldn't call them counter weighted when in stock form. I am not convinced they even need the counter weights...
note how you can still see the pooches between 1-2 & 3-4 rod journals.I wouldn't call them counter weighted when in stock form. I am not convinced they even need the counter weights...
