Turbo, small T4 and the stock cam,
- MattKab
I am nearly ready to assemble my T4. While I'm holding out for serious parts for a 'bigger' other engine. I'm trying a turbo 1.8, nearly all stock, only after about 7 or 8psi, 5500rpm max. Garret T2 I'd settle for ~135hp
Car is '79 Karmann, will be ~1150kg with me and T4 installed, trans is stock ratio AT with ZF 3250rpm@70mph, 5000rpm@100mph, intended use is Nürburgring (Transcontinental, long distance/high speed/corners).
This engine is temporary and for optimising my T1/Cali cooling, etc. The case is in great shape, I might use it on my 2056 later on.
I have 2 USED stock cam and lifter sets, both are 1974 1.8l T4, 1 is US L-jet and other is UK twin 40 solex..1 is going in this engine in the next week or so. No rush.
No ugly wear patterns on the lifter faces, cam lobes. All indexed to bore.
I'm able to measure and plot the profile of the 2 cam's in crank degrees against lift at the lifter, but I've never chose a cam for an engine. I've built 7 stock T1 engines, with stock cams....
If I see less overlap on 1 cam, I go for this... right? Not that I'm expecting anything remember.
I know the script goes web cam and lifters from Jake but this is sweet cheap practise engine.. All parts to build the bottom end are poshiled/checked/very clean. All new bearings/Curil K2/11 galley plugs/AN-8 oil lines, AN-3 to turbo.
My head choice is T25 with new valves, will go for 41*38 or even 40*40. Petrol is 97/98 RON. CR is undecided.
Opinions please, will it melt? I have 10 channel data logging inc. 4 channel EGT and LM-1 to tune single TB/plenum 2bar MSnS Extra code and EDIS.
I wan't to avoid any need for a cam break in until the rest of the conversion is proven (to me).
Rods and bolts are stock, new big-end shells are Mahle bronzina from Brazil. Same as the mains.
I need some feedback on my plan, tear it apart at will. Is there an obvious cam for this combo? Web 73?
Matt
Matt
1979 Karmann Beetle with 1.8ti T4 (still pastel yellow)
1970 411 Variant (black) daily driver
1964 lil' window Beetle (soon to be black)
Matt. In your case, I would opt for the cam with the most overlap. Many yrs ago I made a rough "dial" on the difference of the T4 cams, and came to the same conclusion as written here. The "E" and the "S" cams are so close to alike that it hurts.
As stupid as one is somethimes, I never got the data written down on more than a piece of the latest newspaper. And guess where that ended
You will be able to find variations within the stock specs. - Again, use the cam with the most duration, if you spot a difference...
135 hp @ approx.9 psi is absolutely possible.
T.
T.
- MattKab
Thanks T., I value your input. I'd like to know the spec on those other cams
I carefully measured 3 stock Bus cams today (exhaust only), plotted them together, put them in a new thread.
Matt
Matt
Heat is the killer.. ALL stock cams were designed to help with the engine's warm up times through a bit of heat retention.
I have been doing R&D work with 100% stock engines+ Turbo for a few weeks already as I design my Turbo kits for TI and 914 applications. I have found the weaknesses already.
More engines will be painfully compromised on purpose in the future as well! I have 3 more to kill before the end of this month!
Can I ask how a cam retains heat?MASSIVE TYPE IV wrote:Heat is the killer.. ALL stock cams were designed to help with the engine's warm up times through a bit of heat retention.
I'm sure its an obvious answer, but if I don't ask the question I'll never get the answer
I'm looking forward to reading of your T4 turbo testing Jake.
Its great to see so many low budget approaches happening now as well.
Jeremy
- MattKab
HEAT is what I'm living to beat Jake. Have fun bursting those old motors.
I found the ground-down remains of the carb cam to have more duration and lift than the remains of the FI cam, both are split-duration at .020" and equal at .050. The carb cam has 2 degrees less lobe seperation angle.
The carb cam will move the heat along quicker. ..? The exhaust valve opens sooner, closes later. Inlet valve opens sooner, closes later. Exhaust valve reaches max. lift 4 crank degrees later..
Was that with one of your spit duration 'custom' cams or a more traditional 'tuning' cam?MASSIVE TYPE IV wrote:Any stock cam is far from optimum, this is clearly illustrated by the 15-20% gains I have logged with only a cam swap in a 100% otherwise stock engine all while running cooler and getting more MPG.
I have always beleived what I read in the Dellorto tech book with regards to split duration cams. In my opinion their potential is commonly overlooked by tuning manufactures, I guess because there applications are so specific to an engine combination.
Good to see you are making them Jake! Shame you can't reveal their specs.
Is that due to the type 4 exhaust port being more retrictive than the intake? From what I´ve heard it´s even more evident on type 4 head oval ports than the bus head square ports.With a split duration do you mean a longer exhaust duration than the intake duration?MASSIVE TYPE IV wrote:Almost all my cams are split duration.. 36 of the 45 cams I have designed or tweeked from other cams are split!
With the TIV if you are not using split duration you are cheating yourself out of power and cooler running heads with more MPG!
Note taken! This must be the case for type 1 engine set ups too then, even if to a lesser degree (excuse the punMASSIVE TYPE IV wrote:Almost all my cams are split duration.. 36 of the 45 cams I have designed or tweeked from other cams are split!
Not sure on which engine it would be for yet! What are your opinions on these? Do you have a cam specifically matched to one or the other (or both?)
71mm x 103mm = 2366 vs. a 66mm x 96mm = 1911.
Both would be using stock cranks and rods, and the 2366 would be using some reworked 38 x 48 vavles, and the 1911 stock sized (maybe +1mm) 2 litre 914 heads.
Cheers,
Dan
