i am still in doubt about whether or not i should start building an oxyboxer since i already have a case lying around.
for the costs i was just wondering about the fanshroud i should use. cos i've seen a few with porsche style shrouds, but i hate the fact that it will cost me like $1000 more since it is so expensive. now, what are the other options i have? are there other kits?
Beherenow.tk wrote:i am still in doubt about whether or not i should start building an oxyboxer since i already have a case lying around.
That stuff is just because there are no oil cooler provisions on a stock wbx case, and there is no other way to add a cooler to the inside of the shroud. You could use whatever shroud that works on a t1 and run a remote cooler, or come up with an adaptor like in the picture.....
For anyone that wants to see that we have done to get a stock type 1 dog house fan shroud with stock cooler you can see lots of pics. At www.rockyjennings.com then go to mickys race car. Rocky
Ephry73 wrote:But I was under the impression that the bolt spacing for the heads was similar to the type 4. true? fiction?
E
Different terminilogy. Bore spacing is the center to center distance between the bores.
You are asking about the cylinder head stud bore spread (there is another term for it). Wasser is different from T1 and T4.
Wasser is close to autocraft "4 inch".
