Hello.
I would like to build a blast cabinet for doing fenders, bumpers etc.
Has anyone done this?
My current thought is to use Slab doors fro the sides and bottom... glass windows for the access/viewing hole.
How do you manage the Hand Access holes?
Any hindsight advice or pointers?
Tim
==Home Made Big SanbdBlast Cabinet===
- Freq2002
For parts that big you're better off getting a resperator & a hood & gettin dirty. Moving larger parts like that from hand holes will be a real PITA.
If you want to localize the mess you can always set up a small enclosure with a tarp to collect the blasting media. Keeps all the sand in one place, you can walk around the part on a table or saw horses & best of all you dont have to find a place to put it all when you're not using it.
I dig all cars, whether old, new, hammered out of Japanese tin cans, American iron, or German steel.
Rides:
70 Volksrod "The Black Bomber"
12 Jetta 2.5
56 GMC 370 "Tater"
07 Avalanche
20 Cherokee Trialhawk
05' Harley FLHTCUI
Rides:
12 Jetta 2.5
56 GMC 370 "Tater"
07 Avalanche
05' Harley FLHTCUI
Coils
I doubt I still got the web site but I think I got a link from this forum, so try a search.
When I went to the site a guy made a blast cabinet from plywood with a 2X3 frame, he had a chute type thing on the bottom made of plywood (but you might have to get creative for a cabinet that big, like a double chute set-up). There was a fixed piece of glass on the front and it had a door on one side, he said a little media did find it's way through the seam of the door. The gloves he bought from a company that makes blast cabinets, and if I remember right he just used a cheap gravity feed blaster he bought at sears.
Hope this gives you a general idea of a cheap home built cabinet.
- Kubel Nick
I bought long rubber gloves (or get sand blasting gloves) and used a pipe clamp (similar to a round exahuast clamp) around a similar diameter PVC pipe to use as my hand port holes.
You'd probably want a hole where you can stick a dry vacuum hose into and some lights inside as well so you can see.
Everything else is just a normal box with a hole in the bottom and glass on top. I made my hole funnell down the middle to collect the media into a bucket that sits below my cabinet.
- Rescue912
An old chest freezer works wonders. Grab the local paper and twice a month there will be somebody who will about pay you to take one away. Rubber seals around the edges and most have locks on the doors.
Few minutes with a sawzall, pop in some glass - well, plexi ... *BAM*
Usually has a cord for that light you are gonna need in there too
Coils
This is not the one I mention earlier but it's a start.
http://www.ford-trucks.com/article/idx/ ... binet.html
stkrmtr
radiobirdman32
blasting cabinet
I made my own cabinet out of an old computer cabinet. It is one of the old ones that already has a plexiglass window and dust sealed flip down door to protect the computer from dust. To protect the original plexiglass, I made a little frame on the inside of the window that takes pieces of cheap thin plexi that are easily replaced. The cabinet was already wired and on wheels. I use an old cartridge water filter element on the exhaust and long chemical gloves hose clamped on to short rings of ABS pipe. Works great although I do get some dust after the 60 mesh sand breaks down. I'll have to try the Crystalgrit. Anybody ever used walnut shells?
