External Cooling
Rip
External Cooling
I've got a DTM and I don't think I'll really need more cooling, 2056. But I do have the chance to get air flow to a ext cooler, and was thinking better safe than sorry.
should I?
I'd route it to the front of the car via copper tubing, thus also adding to the oil volume, I'd also use a thermo so it would get up to op. temps. Any advise?
Anyone running a DTM with a ext cooler?
thanks
Rip
should I?
thanks
Rip
NextGen
Personally I would say forget the extra cooling. Unless you are going to be racing at high speed for hours in a hot climate and your engine is tuned to full race.
From my experiance the T-1 fanhousing is enough to cool an engine of your size and a daily driver. The DTM will surely keep it cool and put the air in the correct places..
Joe
Joe
Joe Cali
The Type IV Upright Conversion Manual
Beetle Magnetic Deflector Shield
http://www.nextgen-usa.com
Next Generation-U.S.A.
Email: [email protected]
or
[email protected]
or
[email protected]
- new2bugs
HUH?
I am curious where is this extra air coming from, that you are so desparate to put to good use. I think Even After I am done doing my conversion I would still like to do the external oil cooler and filter. For the simple reason I will be driving around all summer in over 100 degrees of weather. Plus I am not sure when I will be able to upgrade the tranny.
Tim
Tim
NextGen
Years ago I met a guy that made scoops in the front of his bug. ran tubing into his heater channels in his trunk. The air blows out of his heater channels to ducts and up to the fan intake.
Reverse system. OK so no heat unless he has a gas heater.
Joe
Joe
Joe Cali
or
[email protected]
or
[email protected]
- shambly
Hmmm. I'm installing a 2270 C with DTM in my Speedster here in the UK.
I have a similar question of whether to go with an external oil cooler from day one or not?
(I have a 3.44 f/d in my trans-axle with 0.93 4th)
Jake, given everything else i'm doing in preparation for the fitting the engine, what do you think? Fit a cooler now and be done with it, or wait and see if its really needed in our climate?
Thanks,
Simon
Thanks,
Simon
- samcat
