t4 heater box question
- barls80
im running a t4 2L in my bug and would like to change the exhaust to a twin muffler set up. im currently running shortened kombi heaterboxes. my question is can the boxes be swapped from the left to the right so that the flange on the box faces forward instead of backward. mere is my current set up minus muffler
- Boneloader
NextGen
Wow those are interesting heater boxes!!! Lets hear the story.
Joe Cali
The Type IV Upright Conversion Manual
Beetle Magnetic Deflector Shield
http://www.nextgen-usa.com
Next Generation-U.S.A.
Email: [email protected]
or
[email protected]
or
[email protected]
- aircooledtechguy
pantswagen
hello
the exhaust mounting flanges on vanagon heads look similar but
one of the pair has the mounting holes off-set
this would lead me to believe that you couldn't swap them around
i tried this with some stubb pipes
i wouldn't know about the earlier style
but would recommend you finding some 914 exhausts
as they exit rearwar stock, and are quite long, and am sure, if you boxed clever, you could un pic the heater box and seperate the two pipes and bend them?
- aircooledtechguy
All type 4 heads to my knowledge have the offset pair of studs on one of the ports (both oval port & square port heads). This offset pair of studs is what makes the 1&2 side heaterbox face aft or if you bolt the same heater box to the 3&4 side, it will ONLY face fwd. I hope that'sw not confusing. . .
Merry Christmas everyone!!
- raygreenwood
To my knowledge....the standard type 4 units do not have offset manifold bolts....unless you guys are speaking of something I totally have no knowledge of (happens every day
). The ports on my 1.7 seem to be right in line with each other....but because of the shape of the exchanger...you can't swap them anyway. Ray
