AVP head
ratwell
AVP head
Post by ratwell »
I've got a new AVP head that's leaking down 50% on the exhaust valve. I've got some grave concerns about install it and hoping it will fix itself.
Does anyone have a recommendation besides send it back and buy a head from someplace else?
HAM Inc
Post by HAM Inc »
Don't install it. If the valve is leaking that much, something is bad wrong. I'm assuming you checked it with a leak down tester? If so try tapping the valve lightly with a brass hammer. If this doesn't bring the leakage down to 2% or less then you have a problem. If the seat is not concentric the valve can grab it and yank it out of the head, (this can be catastrophic). At the very least you'll burn a valve.
If the shop that did the work won't make it good, then you'll know not to use them again!
Post by MASSIVE TYPE IV »
Damn....... 50%?
DAMN!
If you goahead and install it you may as well be pissing up a rope..
ratwell
Post by ratwell »
HAM Inc wrote:Don't install it. If the valve is leaking that much, something is bad wrong. I'm assuming you checked it with a leak down tester?
Yes. Here's the leakdown gauge in action: http://tinyurl.com/5koxg
The other cylinders on this never run engine (rebuild) are leaking 4-6% which I would expect before doing the test.
I'm afraid of burning it.
Thanks for the advice.
HAM Inc
Post by HAM Inc »
If I did a pair of heads that leaked a low of 4% and a high of 50% I'd fall on my sword!
And people still wonder why good heads cost..............
This is a great illustration.
ratwell
Post by ratwell »
The heads came with a longblock. This is a budget repair for a friend and I'm not quite ready to write these heads off yet although as you both confirm they are very scary.
Good work that's error free and guaranteed costs money. No doubt about that.
Bobby74
Post by Bobby74 »
try lapping the valves to see what type of contact area the valves are making with the seats. If you're lucky, you might be able to get by with re-lapping the valves. If its too far off, you'll have to get the seats and valves ground to the same margins.
turboteener
Post by turboteener »
Do not lap valves on a good valve job or on any engine you care about. The valve lapping compound will embed itself in the seat and valve and promptly kill the valve seal over the (short) life of the engine.
turboteener wrote:Do not lap valves on a good valve job or on any engine you care about. The valve lapping compound will embed itself in the seat and valve and promptly kill the valve seal over the (short) life of the engine.
I know I'm resurrecting an ancient post, but I have to say "Huh?" to this one...
I have ALWAYS lapped my valves in, and have always gotten great service from them, no issues, ever, over many many hundreds of thousands of miles, mostly in ACVWs.
I have never had as much as not having one liquid-tight (solvent) when checking before I replace the ex valves at ~50K. They don't even ooze.
People have been lapping in valves for 100+ years without issue, so once again, I have to say "Huh???"
Perhaps you forgot to clean them off?
blue77bay
Post by blue77bay »
not only do i lap valves i also lap cylinders ,no problems here ?????????????
be ultra ultra thorough when cleaning ,then clean again :D
Class 11 streeter
Post by Class 11 streeter »
I think I remember Len saying he laps valves with a compound so mild it makes DIY off the shelf lapping compound look like gravel.
Class 11 streeter wrote:I think I remember Len saying he laps valves with a compound so mild it makes DIY off the shelf lapping compound look like gravel.
Yes, he uses the same "ajax" trick that I have spoken about here in the past.. There hasn't been a fine enough lapping compound on the market for us in years..
Comet or Ajax mixed with a tad of water works wonders.
I have a bottle of 5 micron alumina here that should do...
Jotunrunner
lap?
Post by Jotunrunner »
lap? huh? ajax? really? -this is something ive never heard of, and never dream of trying without a lot more info. anyone care to illustrate this procedure?
