are super diffs universal or swing and irs specicic?
will a IRS superdiff fit a swing axle tranny also is the question? thanks in advance. Mitchell
Ooooh, didn't know that (we don't get many 10-tooths down here). Where do you get a SuperDiff for the 10/15 setup? Is that the difference between CBPerformance's #4552 and #4554? (they don't give any details other than the #4554 "racing" unit fits all `61-`68 swingaxles).
Would a SuperDiff be mandatory in a ~175HP/1600lb/slicks drag swingaxle application or would the stock 10/15 stuff be enough? ...I'm in the market if you have some to sell...
Marc, the late SSC IRS diffs come with 10/15 gears. Early IRS had 11/17 gears. The same happened to swing axle in 73.Marc wrote:Ooooh, didn't know that (we don't get many 10-tooths down here). Where do you get a SuperDiff for the 10/15 setup? Is that the difference between CBPerformance's #4552 and #4554? (they don't give any details other than the #4554 "racing" unit fits all `61-`68 swingaxles).
The two CB diffs will both be for 11/17 gears. One has double snap rings, the other is threaded. But if those diffs are exactly as pictured, don't get either. The tiny 1/8" roll pins shear off real easy, then the shafts fall out. I've got the remains of a Berg 5 in my garage right now that was wasted by a diff like the one in that pic (4552). The newer diffs from ERCO have larger 1/4" roll pins. And they use a super thick snap ring instead of two thin ones. ERCO does sell a swing axle superdiff machined specifically for 10/15 gears.
If you want a set of 10/15 swing axle gears, I have a set, magnafluxed.
Are the swingaxle 10-tooth spiders interchangeable with late IRS? If not, I guess I'll need four of those if I get the ERCO SuperDiff.
I presume the stock 10/15 swingaxle housing is different than the stock 11/17 unit also? If so, and I decide to risk using the stock setup, I'll need a housing also.
Not in any hurry, project is probably a year away.
- Henryhoehandle
Marc,Marc wrote:Are the swingaxle 10-tooth spiders interchangeable with late IRS? If not, I guess I'll need four of those if I get the ERCO SuperDiff.
Yes, the swing 10 tooth spiders are interchangable between IRS and swing, as is the 11 tooth ones. Weddle sells 10 AND 11 tooth spider superdiffs for either swing or irs. Yes the housings are different and you must use whatever spiders the housing was made for.
- Henryhoehandle
The superdiff housings are different for 11/17 vs. 10/15 gears. But if you have a stock diff housing, they are all the same for both gear sets. IRS and Swing.
The difference lies in the angle of the second spider gear axle relative to the first. In order for the gear teeth to properly mesh, you have to alter the angle of the second pair of spiders off 90º. And this off angle is different between 11 tooth spiders and 10 tooth gears.
- Henryhoehandle
Bruce clarified this... stock diffs are the same and superdiffs are differentPJMS wrote:I don't think the housings are different. I believe they are the same for swing axle from 67 onwards, no matter if you use 11 or 10 tooth spiders.Henryhoehandle wrote:....Yes the housings are different and you must use whatever spiders the housing was made for.
