What wire do I buy for mig welding galvanized pipe? Or do I use the same wire as for mild steel? and put primer on the welds?
Kevin
Mig welding galvanized
- A_67vdub
Whatever you do, don't breath the fumes or you will get sick (not high, sick). They say you're not supposed to weld galvanized at all, but I did it anyway and held my breath during welds and took lots of breaks, and still got a headache and kinda queezy from it. I used the same wire as mild steel.
Steve
Steve
- Honda's Killer
- Searoy
1960 ragtop
Here is the deal. To weld galv. material grind off the galv. coating in the area to be welded. Then weld it just as you normally would. then you can buy cold galvanizing compound in a spray can. If your only welding a few joints you will be fine. I still don't like to breath the smoke though. You can get zinc poisoning if you breath to much.
- Puck
Not only does galvinizing produce bad fumes it also contaminates the weld. The weld usually turn out looking horrible and probably not too strong. At least with TIG.
Muratic acid will take galvinizing off. Grinding will work also but remember if you are welding pipe the galvinizing will still be on the insie and will also burn off and produce fumes.
If you do use muratic acid do it in a WELL VENTILATED area. This stuff is nasty. Cheap as dirt though. Wear a mask and gloves. It burns skin. And dip the part in SLOWLY. It bubbles as the zinc comes off. You can get it at a pool supply or even Home Depot.
One thing it works great for is stripping the zinc off of nuts and bolts that need to be welded.
general_lee_jr
