Tweaking HP out of Wasserboxers.
Ceebers
Post by Ceebers »
I have a MV 2.1 in my 88 Vanagon.
I recently installed a performance? eprom chip in the ecu, and bumped the timing up to 10 btdc, as indicated with the chip I bought for the digifant f.i.
I definitely feel an increase in power from the start, and in the mid rpm range where the power band seemed to lack a bit.
What are some other ways to tweak a bit more power out of the engine? K&N filter, different wires and plugs, etc..?
Thanks a lot.
Type 5 Joe
Post by Type 5 Joe »
You could install some solid rockershafts, swivel adjusters from C.B. Performance...
They make a set of 9mm swivel foot adjusters that will go right in your rocker arms...
They also sell a set of 1.25 ratio rocker arms that are the 9mm's These are factory rockers that have the pushrod cup re-located for more ratio.
Set-up your valvetrain geometry with cut-to length pushrods (if needed) and rocker stand shims.
K&N aircleaner would be good...
Up-graded ignition products would be good...
Good Quality oil in the motor / Tranny would be good...
A good quality exhaust system (header) That's about it without tearing into the motor... Maybe I missed something?
Service the C-V Joints / re-pack all the wheel bearings.
6 ply tires reduce the rolling resistance / help with handling / Improve gas milage / last far longer than regular tires on a Bus.
These tires are the ones reccomended for mid-sized Ford trucks ... Explorer? I'm not shure exactly..
- Joe
Ceebers
Post by Ceebers »
Thanks Joe,
I am new to this forum, and to Wasserboxers, being a type 4 bus guy for most of my vw life...
what would I upgrade in the ignition, and are any brands or models better than others, in your opinion?
Thanks!
Type 5 Joe
I can only reccomend the mechanical / internal modifications... The factory ignition is a good system.
My specialty is building motors... I have done quite a few built wasser motors / related components. These are usually carburated....
My specialty is the Type 5 conversion... Converting to air cooled for Dunebuggies, sandrails, earlier street cars, race cars.
I'm not shure if the Mallory ignition system is compatible with your fuel injection.
i don't give out advice on subjects that I have no experience with...
Maybe someone else on here can speak from experience, or you could describe what you want on the fuel injection Forum?
Good Luck with your project. - Joe
JohnConnolly
Post by JohnConnolly »
we just finished our prototype turbo kit for the 2.1L Vanagon, it works VERY well. You can also put a "chip" in the stock ECU for an 8hp increase on a stock engine, or a 30hp increase on one with some 1.4/5 rockers.
we will have the chips in 2 weeks if you are interested.
John
Aircooled.Net Inc.
Guest
Post by Guest »
Wow, that sounds cool, John.
- Joe
The 9mm adjusters ONLY fit the CB 1.25 rockers--- Them fitting the std rockers is a bit of disinfomation I started. (my bad) Stock VW/wasser are 10 mm. A cheap way to go would be T1 1.1:1 rockers, they have 8mm adjusters, and would take the Real Porsche adjusters John sells, probably need the same .060 inch removed for clearance, easy to do. Should practically eliminate guide wear//adjustments, even with solid lifters.
I have hear nothing but good things from bolting on Berg (or Scats copy) 1.4 rockers, assuming a stock cam.
With the chip, it should really sing... 30HP is a LOT from a bolt on combo on a 95HP engine, but appears realaistic, as Boston Bobs #s are about the same, even more with a little porting/big valves.
I'll be harassing John in 2 weeks... If it doesn't hurt too bad.
(Discounted combo on rockers + chip?)
Ceebers
Post by Ceebers »
The turbo setup for the vanagon sounds great, any pics of that John?
Guest
Post by Guest »
Yes it does, lets see some pix!!!
TIMBERWOLF
Post by TIMBERWOLF »
Is the 1.4 berg rocker + porsche adjusters still OK on a 1.9 with an engle 120? I tried to find out a little while ago, but found out that I needed to disassemble and check all the clearances with a dial indicator etc etc....
The Berg/Scat rockers cannot use the Porsche adjusters, mutually exclusive parts.
JohnConnolly
I can't post the pics, but if you send me an e-mail I can send them to you.
chip is available at
http://www.aircooled.net/new-bin/viewpr ... d2=FSI0009
Rockers at http://www.aircooled.net/new-bin/viewpr ... d2=ecv0008
John
Aircooled.Net Inc.
Ceebers
Post by Ceebers »
John, send pics to [email protected]
What do you think a production turbo would go for?
Thanks,
Chris
Links arent working for me... icq.com does not connect.
(I don't use ICQ if that matters...)
Beetle envyy
Post by Beetle envyy »
John, if you'd like i can post the pix you sent to me...
