78mm Stroker Crank Forged or Cast??
Floyd
Has anyone had any experience with cast Stroker cranks?
I'm building a 2007cc daily driver, I'm searching for 78 crank,
I see cast and forged availble, are cast cranks really risky?
I have no experience in this area.
If any one has used one for sale please let me know.
Thanks.
Thanks.
- turboblue
Type 5 Joe
- gerico
Joe, you said you have used the CB cranks. Were you happy with them?? Is nitriding worth the extra $50?? $190 to $240 for a decent forged 76mm crank sounds like a great deal. Emphasis here is on "decent". Hate to be cheap but budget constraints won't allow a $400+ crank and I would rather go with a high quality forged German 69mm crank than a poor quality stroker.
Glen, I agree. Somebody said you can tell the difference between a cast and forged crank by tapping them with a hammer and listening to the sound. The forged crank rings, the cast crank breaks.
Type 5 Joe
They are a good value....
You can only get the Nitride option on the 4340 Cranks.
I just ordered another 76mm last Friday for a customer.I wouldn't be buying any if I have had problems.
The only thing the Nitride Treatment does is increase the wear-resistance slightly... If your on a budget, go with a full-flow oil system, ect..
Proper Machine work / Assembly / Engine Combo / Maintenence... Will be the best investment in any case.
Run a German Dog-House Cooling system with the flaps / Thermostat
Be realistic about your application... Most street / Off-Road motors like small ports and small duration cams.
Good Luck, - Joe
Good Luck, - Joe
- gerico
Joe,
Thanks for the feedback on the crank, they sound like a REALLY good buy.
If I go with one of the CB 76mm cranks I'll use 90.5 P&C, CB cromoly rods, 40x35 heads, and either an Engle 110 or possibly a Web 218 cam, maybe about 7.5 compression, and a 1 1/2" merged header. Get Rimco to balance everything. It's going to be a daily driver...my primary transportation so it has to be reliable and have decent throttle response in trafffic. I have a doghouse system, the parts for an external filter, a 1 1/2 qt sump, and a couple of AJs kads w/ aluminum manifolds. Probably use a 5800 rpm rev limiter.
Sound OK?
Sound OK?
Type 5 Joe
RoWaMe
A few years ago I bought a new 78mm cast crank for relatively cheap at a local swap meet. The engine for it is nearly finished- also a 2-liter (78x90.5), stock-valve heads (home-ported), engle 110 cam, 7.9:1, and 1 3/8" headers. Topped with used German tin/thermostat/flaps and 36 Dell's- it'll be for a highway cruiser engine with no drag-starts nor high revs. If I can only get the too-tight endplay finally set...
